3CX Web Meeting Error
Discussion in '3CX Phone System - General' started by cmunteanu21, Apr 29, 2015.
  1. cmunteanu21
    Apr 29, 2015
    I'm trying to delete an extension but the username is configured with 3CX WebMeeting . The webmeeting is deactivated so I want to activate it again .
    When I click settings -> Web Meeting -> Activate , I receive the error attached in the image , and user and access upper menu from webmeeting is not appearing.
    I've also restarted the machine .
    Can someone help me to get rid of this error , and finaly remove the extension ?
    3CX System Standard Edition , Version v12 with SP 6.1 .
  2. gtoprak
    May 4, 2015
    Try install and activate 3CX System 12.5
  3. cmunteanu21
    Apr 29, 2015
    Thank you , installing 3CX v12.5 worked.
    Also I t've submited a ticket to 3CX and they've helped me for user deletion.
  4. serverwork
    Nov 15, 2012
    14
    We are seeing the same error. However, we are unable to upgrade to 12.5, as we are using 3cx Cloud.
    I have deactivated and reactivated both the Webmeeting license, and the actual PBX license - with the same results.
    Thanks!
  5. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    I had this issue with 12.5. The fix is to backup, uninstall and then re-install and load configuration from backup. Doing the same on your v12 cloud instance should also fix it.
  6. serverwork
    Nov 15, 2012
    14
    Thanks lifeline, I tried your suggestion. However, I still get the error. I am submitting a ticket. I'll let you all know how it goes.
