3cx webmeeting app problems
Discussion in '3CX Clients' started by rvoosterhout, Feb 6, 2018.
  1. rvoosterhout
    May 24, 2017
    47
    Hi everybody,
    I'm using the 3cx webmeeting app on iOS, but i can't find the button's to open my camera. Now i can only see the calling caller my iphone screen, but the caller can't see mee on his computer screen.
    These are the buttons i'm talking about:
    [​IMG]
    Is there a special way to see these buttons?
    Kind regards,
    Rick
  2. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    229
    18
    Hello @rvoosterhout
    When you press settings,is the camera marked with a Yes?
    Press on the i button and make sure that camera is enabled
  3. IoannisM_3CX
    Aug 10, 2017
    229
    18
    @rvoosterhout
    also can you please tell me which MCU are you using? You can find this under the Information panel of your Dashboard in the Webmeeting MCU field
  4. AJ Smith
    Aug 4, 2017
    23
    Same issue. Following
