3CX webmeeting for 3CX phone system
Discussion in '3CX Phone System - General' started by rsaxe17, Mar 23, 2016.
  1. rsaxe17
    Jan 31, 2016
    16
    Hello Members,
    By using integrated 3CX webmeeting, can we authenticate members before allowing them to join a session ?
    Thanks,
    Rishi
  2. rsaxe17
    Jan 31, 2016
    16
    Hello Members,
    Is there an option to create 3cx web meeting accounts per user for integrated 3cx system or is this option only available in a dedicated 3cx webmeeting server ?
    thanks,
    Rishi
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,500
    98
    Hi rsaxe17,
    To answer your first question about authenticating members before allowing them to join a session.
    1)
    -There is no feature to authenticate participants before allowing them to join a session.
    When you create a meeting, only you have access to it. When you invite participants to this meeting using the e-mail option, only they can join this meeting because only they have the meeting link. This meeting link can only be used by 1 person at a time which means while person A is connected using this link, a second person will not be allowed to connect using the same link.
    All links generated when sending e-mail invites are unique to each person. Everyone gets a different invitation link.
    This IS considered to be the authentication you're looking for. If you are having problems with people sharing their personal meeting links with other people or people having access to each other's e-mails, this is an internal security issue within the company you are in.
    To answer your second question in regards to the WebMeeting accounts per user:
    2) If you try to access your WebMeeting url on your browser e.g: mycompany.3cx.eu you should see a login panel. If you only see a screen with two buttons on it, it means that by default we've disabled access to the WebMeeting Portal/Management Console and you need to contact our support for us to enable it for you. From here you will be able to create WebMeeting accounts per user and each user will be able to create and edit his own meetings.
    I hope the above answer your questions.
