3cx Webmeeting
Discussion in '3CX Phone System - General' started by Eliq91, Jan 10, 2018.
  1. Eliq91
    May 2, 2017
    13
    When opening the management console and going to Conferencing settings I do not see a server under Video conferencing (webmeeting). [​IMG]
    We have a professional license that should have 50 seats. [​IMG]
    Any suggestions would be great.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Hello @Eliq91
    Please make sure the port 5001 is open in order for the PBX to be able to reach the webmeeting servers. You could also try restarting the system service of the PBX and see if that helps.
  3. Eliq91
    May 2, 2017
    13
    I restarted the services and got the following notification.
    The FQDN you configured at installation time is not linked to the license key which is currently activated. As a result, video conferences cannot work. Activate the license used at FQDN creation time or re-install and use your new license key and link it to a new FQDN.
    I logged into the customer portal and verified that the FQDN matches the license key in my activation. license.PNG
  4. YiannisH_3CX
    May 10, 2016
    4,443
    282
    Can you send me in a personal message the licence and your FQDN as well as the webmeeting FQDN so we can investigate on our side?
