3CX webRTC using Open Format
Discussion in '3CX Phone System - General' started by Bankstone, Dec 29, 2015.
  1. Bankstone
    Dec 19, 2015
    10
    Is it possible to use the open format of webRTC to connect to
    the 3CX system without loading the 3CX logo,
    ie write your own, using the JavaScript Open Format as there are
    some good examples about,
    The only way I can sell this on to customers is to white label it
    so they can add their branding. As I see it the back end would always be 3CX
    The best way of doing this is 3CX for calls
    and Asterisk for webRTC, using Open webRTC,
    It also gets round the issue with SSL and Abyss.
    Its easy enough done, essentially 2 PBX's per phone
    I don't want to rebrand the softphone, just the webRTC that the
    end user of the customer gets as I have a number of confusing reports back
    with end user customers not knowing who they are dealing with.
    This I can understand
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    This has been addressed by Nick Galea himself here:
    http://www.3cx.com/forums/corporate-logo-customizations-rejected-partially-41967-s15.html
