3CX Win SBC and Yealink - BLF not working
Discussion in '3CX Phone System - General' started by repa, Mar 13, 2015.
  1. repa
    Mar 13, 2015
    10
    we have installed a 3CX Cloud Version 12, with Session Border Controller on Windows (as Raspherry PI Version is not provisioning new phones) and Yealink T46G and T48G.
    Everything works fine, except the BLF Provisioning. The BLF Lights are not showing up. Any hint on this?
    Yealink are on the newest firmware.
  2. repa
    Mar 13, 2015
    10
    after resetting the phone and provisioning again, the buttons appears. But, when i change the buttons in 3CX, how long does it take, until they appear on the phone?
    i can reboot and reprovision the phone, the buttons are not getting changed?!
  3. gbardissi
    Feb 4, 2015
    28
    I don't recconend the 3CX sbc app with cloud server.
  4. gbardissi
    Feb 4, 2015
    28
    Not stable enough and when do cloud deployments in volume you really need a sever side SBC.
  5. repa
    Mar 13, 2015
    10
    What do you mean with SErverside SBC?
    we also tried to connect the yealink phones using OPenVPN, without SBC.
    The BLF still want get updated... Looks like has nothing todo with SBC?
  6. repa
    Mar 13, 2015
    10
    no hints?
  7. repa
    Mar 13, 2015
    10
    i kicked the SBC out and configured an openvpn connection again.
    problem still persist, no BLF are updated... any hint??
  8. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    What if you connect one Yealink directly to your 3CX cloud server to test if you can provision the BLF?
    No SBC, no OpenVPN, just for testing.
    Does it work then?
    Is this the firmware supported by 3CX?
    Have you open and/or forward the proper ports in your firewall?
  9. repa
    Mar 13, 2015
    10
    yes, we tried everything with newest, 3CX Supported and 2nd newest firmware. didn't work at all.
    we got it working now like that:
    SBC, DHCP Opion 66. When we change the BLF, the user has to long push "OK", initiate a factory reset.
    Yealink gets Option 66, provisions, reboots again and then, all BLF appears correctly.
    Stupid way, but works.
  10. rsh
    rsh
    Mar 25, 2011
    17
    Try provisioning with http instead of https (some certificates are not accepted by yealink)
