3cx win softphone
Discussion in '3CX Phone System - General' started by giulio-tn, Nov 15, 2016.
  1. giulio-tn
    Nov 15, 2016
    the system is 3cx linux v15 sp3
    the client is windows softphome in terminal service environment ( windows server 2012R2 )
    the problem:
    first call to external or internal is ok ( the status are red and yallow )
    after handset down the status is green
    the next recall not dial the number, if i close the application and restart the call is ok.
    any suggestions
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,443
    540
    Hello there,
    Do you have any audio devices under settings/ audio options?
    this is usually caused if there are no audio devices listed there
  3. giulio-tn
    Nov 15, 2016
    This was the problem ....
    Thank you for your quick answer
