3cx windows app to Phone cause phones to unregister
Discussion in 'Windows' started by joshjeffries, Feb 12, 2015.
  1. joshjeffries
    Feb 12, 2015
    I am having a very strange issue. I am using the 3cx app on my windows machine with a headset to call/receive calls from another user in a remote office on their Cisco IP deskphone. There is a VPN link between office's and the cisco phones are running off the 3cx as well, so it is just dialing the extension number.
    The issue i am getting is every time i place a or receive a call using the headset/3cx windows app to the remote office it will connect and sound fine for around 30 seconds then it will disconnect and some of the Cisco phones in the remote office will unregister/drop off (note not all of the phones unregistered). Also the phones at the main office stay connected and registered at all times.
    Here is the system log whilst it happens. There is a call from 654 to 504 this is the cisco phone in remote office calling me on my softphone. Then once the call has dropped the other user places another call to me (504) using an external phone on a different system)
    12-Feb-2015 16:59:59.735 Leg L:260.4[Extn] is terminated: Cause: BYE from PBX
    12-Feb-2015 16:59:59.734 [CM503008]: Call(C:260): Call is terminated
    12-Feb-2015 16:59:59.734 Leg L:260.1[Line:10000<<*****26535] is terminated: Cause: BYE from 91.151.*.*:5060
    12-Feb-2015 16:59:56.870 Currently active calls - 1: [260]
    12-Feb-2015 16:59:47.611 [CM504001]: Endpoint Extn:671: new contact is registered. Contact(s): [sip:671@192.168.*.*:5060 / 671]
    12-Feb-2015 16:59:46.968 [CM504001]: Endpoint Extn:656: new contact is registered. Contact(s): [sip:656@192.168.*.*:5060 / 656]
    12-Feb-2015 16:59:44.028 [CM504001]: Endpoint Extn:653: new contact is registered. Contact(s): [sip:653@192.168.*.*:5060 / 653]
    12-Feb-2015 16:59:43.650 [CM504001]: Endpoint Extn:654: new contact is registered. Contact(s): [sip:654@192.168.*.*:5060 / 654]
    12-Feb-2015 16:59:42.759 [CM504001]: Endpoint Extn:685: new contact is registered. Contact(s): [sip:685@192.168.*.*:5060 / 685]
    12-Feb-2015 16:59:39.558 [CM504001]: Endpoint Extn:658: new contact is registered. Contact(s): [sip:658@192.168.*.*:5060 / 658]
    12-Feb-2015 16:59:39.525 [CM504001]: Endpoint Extn:655: new contact is registered. Contact(s): [sip:655@192.168.*.*:5060 / 655]
    12-Feb-2015 16:59:38.944 [CM504001]: Endpoint Extn:657: new contact is registered. Contact(s): [sip:657@192.168.*.*:5060 / 657]
    12-Feb-2015 16:59:24.867 Currently active calls - 1: [260]
    12-Feb-2015 16:58:52.864 Currently active calls - 1: [260]
    12-Feb-2015 16:58:43.029 [CM504002]: Endpoint Extn:653: a contact is unregistered. Contact(s): []
    12-Feb-2015 16:58:42.810 [CM504002]: Endpoint Extn:655: a contact is unregistered. Contact(s): []
    12-Feb-2015 16:58:42.505 [CM504002]: Endpoint Extn:671: a contact is unregistered. Contact(s): []
    12-Feb-2015 16:58:42.297 [CM504002]: Endpoint Extn:654: a contact is unregistered. Contact(s): []
    12-Feb-2015 16:58:42.280 [CM504002]: Endpoint Extn:658: a contact is unregistered. Contact(s): []
    12-Feb-2015 16:58:42.043 [CM504002]: Endpoint Extn:656: a contact is unregistered. Contact(s): []
    12-Feb-2015 16:58:42.018 [CM504002]: Endpoint Extn:685: a contact is unregistered. Contact(s): []
    12-Feb-2015 16:58:40.783 [CM504002]: Endpoint Extn:657: a contact is unregistered. Contact(s): []
    12-Feb-2015 16:58:38.821 Leg L:260.3[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 192.168.*.*:5060
    12-Feb-2015 16:58:38.820 [CM503003]: Call(C:260): Call to <sip:504@192.168.*.*:5060> has failed; Cause: 487 Request Terminated/INVITE from 192.168.*.*:5060
    12-Feb-2015 16:58:38.810 Leg L:260.2[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 192.168.*.*:54015
    12-Feb-2015 16:58:38.810 [CM503003]: Call(C:260): Call to <sip:504@192.168.*.*:5060> has failed; Cause: 487 Request Terminated/INVITE from 192.168.*.*:54015
    12-Feb-2015 16:58:38.792 [CM503007]: Call(C:260): Extn:504 has joined, contact <sip:504@192.168.*.*:5060>
    12-Feb-2015 16:58:38.792 [CM503007]: Call(C:260): Line:10000<<*****26535 has joined, contact <sip:*****9500@sip.voip-unlimited.net:5060>
    12-Feb-2015 16:58:38.791 L:260.4[Extn] has joined to L:260.1[Line:10000<<*****26535]
    12-Feb-2015 16:58:36.242 [CM503025]: Call(C:260): Calling T:Extn:504@[Dev:sip:504@192.168.*.*:54015;ob,Dev:sip:504@192.168.*.*:5060,Dev:sip:504@192.168.*.*:5060] for L:260.1[Line:10000<<*****26535]
    12-Feb-2015 16:58:36.240 [CM503025]: Call(C:260): Calling T:Extn:504@[Dev:sip:504@192.168.*.*:54015;ob,Dev:sip:504@192.168.*.*:5060,Dev:sip:504@192.168.*.*:5060] for L:260.1[Line:10000<<*****26535]
    12-Feb-2015 16:58:36.239 [CM503025]: Call(C:260): Calling T:Extn:504@[Dev:sip:504@192.168.*.*:54015;ob,Dev:sip:504@192.168.*.*:5060,Dev:sip:504@192.168.*.*:5060] for L:260.1[Line:10000<<*****26535]
    12-Feb-2015 16:58:36.188 [CM503027]: Call(C:260): From: Line:10000<<*****26535 ("*****9504:" <sip:*****26535@192.168.*.*:5060>) to T:Extn:504@[Dev:sip:504@192.168.*.*:54015;ob,Dev:sip:504@192.168.*.*:5060,Dev:sip:504@192.168.*.*:5060]
    12-Feb-2015 16:58:36.188 [CM503004]: Call(C:260): Route 1: from L:260.1[Line:10000<<*****26535] to T:Extn:504@[Dev:sip:504@192.168.*.*:54015;ob,Dev:sip:504@192.168.*.*:5060,Dev:sip:504@192.168.*.*:5060]
    12-Feb-2015 16:58:36.187 [CM505003]: Provider:[VoIP Unlimited] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhoneSystem 12.0.37098.738 (34969)] PBX contact: [sip:*****9500@79.77.*.*:5060]
    12-Feb-2015 16:58:36.187 [CM503001]: Call(C:260): Incoming call from Line:10000<<*****26535 to <sip:504@192.168.*.*:5060>
    12-Feb-2015 16:58:36.187 Line limit check: Current # of calls for line Lc:10000(@VoIP Unlimited[<sip:*****9500@sip.voip-unlimited.net:5060>]) is 1; limit is 32
    12-Feb-2015 16:58:36.087 [CM503012]: Inbound any hours rule (*****9504) for 10000 forwards to DN:504
    12-Feb-2015 16:58:20.678 Leg L:259.1[Extn] is terminated: Cause: BYE from PBX
    12-Feb-2015 16:58:20.678 [CM503008]: Call(C:259): Call is terminated
    12-Feb-2015 16:58:20.678 Leg L:259.2[Extn] is terminated: Cause: BYE from 192.168.*.*:54015
    12-Feb-2015 16:57:50.858 Currently active calls - 1: [259]
    12-Feb-2015 16:57:47.546 Leg L:259.4[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 192.168.*.*:5060
    12-Feb-2015 16:57:47.546 [CM503003]: Call(C:259): Call to <sip:504@192.168.*.*:5060> has failed; Cause: 487 Request Terminated/INVITE from 192.168.*.*:5060
    12-Feb-2015 16:57:47.538 Leg L:259.3[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 192.168.*.*:5060
    12-Feb-2015 16:57:47.538 [CM503003]: Call(C:259): Call to <sip:504@192.168.*.*:5060> has failed; Cause: 487 Request Terminated/INVITE from 192.168.*.*:5060
    12-Feb-2015 16:57:47.428 [CM503007]: Call(C:259): Extn:504 has joined, contact <sip:504@192.168.*.*:54015>
    12-Feb-2015 16:57:47.428 [CM503007]: Call(C:259): Extn:654 has joined, contact <sip:654@192.168.*.*:5060>
    12-Feb-2015 16:57:47.427 L:259.2[Extn] has joined to L:259.1[Extn]
    12-Feb-2015 16:57:45.981 [CM503025]: Call(C:259): Calling T:Extn:504@[Dev:sip:504@192.168.*.*:54015;ob,Dev:sip:504@192.168.*.*:5060,Dev:sip:504@192.168.*.*:5060] for L:259.1[Extn]
    12-Feb-2015 16:57:45.978 [CM503025]: Call(C:259): Calling T:Extn:504@[Dev:sip:504@192.168.*.*:54015;ob,Dev:sip:504@192.168.*.*:5060,Dev:sip:504@192.168.*.*:5060] for L:259.1[Extn]
    12-Feb-2015 16:57:45.976 [CM503025]: Call(C:259): Calling T:Extn:504@[Dev:sip:504@192.168.*.*:54015;ob,Dev:sip:504@192.168.*.*:5060,Dev:sip:504@192.168.*.*:5060] for L:259.1[Extn]
    12-Feb-2015 16:57:45.926 [CM503027]: Call(C:259): From: Extn:654 ("Paddy Stern" <sip:654@192.168.*.*:5060>) to T:Extn:504@[Dev:sip:504@192.168.*.*:54015;ob,Dev:sip:504@192.168.*.*:5060,Dev:sip:504@192.168.*.*:5060]
    12-Feb-2015 16:57:45.926 [CM503004]: Call(C:259): Route 1: from L:259.1[Extn] to T:Extn:504@[Dev:sip:504@192.168.*.*:54015;ob,Dev:sip:504@192.168.*.*:5060,Dev:sip:504@192.168.*.*:5060]
    12-Feb-2015 16:57:45.925 [CM503001]: Call(C:259): Incoming call from Extn:654 to "Josh Jeffries" <sip:504@192.168.*.*:5060>
    as another note Cisco phone from remote office to cisco phone in main office works fine with out any issues.
    Any idea's would be much appreciated.
    11,095
    327
    You've X'd out all of the private IP addresses, which is unfortunate, as showing them is not a security issue, but, could help with narrowing down what is going on.
    Does this issue only happen when calling from your 3CX phone? Does any other install of the 3Cx phone calling the same remote extension, work fine?
    Has this problem happened (with any other sets) before you installed 3Cx phone on your computer?
    Off hand, I would suspect an IP or port conflict, but, there could be a setting in one of the the routers causing them to not "play well" with SIP.
  3. joshjeffries
    Feb 12, 2015
    I have actually narrowed this down to the switches in the remote office. It would appear that when the call is made the trunk between the two switches fails cutting off all the phones connected to the 2nd switch.
    I need to do some more test's but will update once i can get some more info from the switches.
  4. attel
    May 30, 2015
    Hi Joshjeffries,
    I am having the same issue with SNOM300 desktop phones: calls are suddenly interrupted and phones reregister (reboot) randomly.
    What information did you found when testing the switches?
    Thank you!
