Solved 3cx windows client voicemail
Discussion in '3CX Phone System - General' started by rsuren, Sep 21, 2017.
  1. rsuren
    Sep 21, 2017
    39
    6
    hi guys,
    we have disabled voice mail for all extensions but in 3cx windows client , when a call comes next to answer button the voice mail button is there out of the 3 options given. so user by mistake clicking voicemail button and call is being lost. is there anyway to disable this in the client. thanks in advance
  2. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    229
    18
    Hello @rsuren
    Unfortunately there is not an option to disable these buttons. I believe that they are quite large buttons so with a bit of more caution when answering, there should be no problem :)
    Thank you
  3. rsuren
    Sep 21, 2017
    39
    6
    actually being big and its being on the right hand side is the issue, our ppl are clicking it by mistake, please in future version give a command line parameter at least to disable the button.
  4. IoannisM_3CX
    Aug 10, 2017
    229
    18
    Hello @rsuren
    You can post any of your suggestions for future implementation in the ideas section of the forum, in order to be up-voted by other users and evaluated by the appropriate department.
    Thank you
