3cx windows clients can't call hardware phones
Discussion in 'Windows' started by opalbiz, Feb 24, 2015.
  1. opalbiz
    Feb 24, 2015
    I was having an issue where 3cx windows clients could not connect to extensions with hardware phones. The phones are Yealink T26 handsets and are all on the same network with the 3cx clients.
    Here is the log:
    24-Feb-2015 12:20:55.365 Leg L:261.2[Extn] is terminated: Cause: 408 Request Timeout/INVITE from local
    24-Feb-2015 12:20:55.365 [CM503003]: Call(C:261): Call to <sip:201@192.168.1.52:5060> has failed; Cause: 408 Request Timeout/INVITE from local
    24-Feb-2015 12:19:51.188 [CM503008]: Call(C:261): Call is terminated
    24-Feb-2015 12:19:51.185 Leg L:261.1[Extn] is terminated: Cause: CANCEL from 192.168.1.125:64355
    24-Feb-2015 12:19:38.777 [CM503025]: Call(C:261): Calling T:Extn:201@[Dev:sip:201@192.168.1.141:5062] for L:261.1[Extn]
    24-Feb-2015 12:19:38.728 [CM503027]: Call(C:261): From: Extn:202 ("James Martin" <sip:202@192.168.1.52:5060>) to T:Extn:201@[Dev:sip:201@192.168.1.141:5062]
    24-Feb-2015 12:19:38.728 [CM503004]: Call(C:261): Route 1: from L:261.1[Extn] to T:Extn:201@[Dev:sip:201@192.168.1.141:5062]
    24-Feb-2015 12:19:38.726 [CM503001]: Call(C:261): Incoming call from Extn:202 to <sip:201@192.168.1.52:5060>
    24-Feb-2015 12:19:38.725 NAT/ALG check:L:261.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
    24-Feb-2015 12:19:34.027 [CM504001]: Endpoint Extn:202: new contact is registered. Contact(s): [sip:202@192.168.1.125:64355 / 202]
    24-Feb-2015 12:19:34.017 [CM504002]: Endpoint Extn:202: a contact is unregistered. Contact(s): []
    Hardware to software works fine, and hardware to hardware works fine. Following a hunch, I checked the PBX delivers audio box for the 3cx phone client extensions and they all can call the hardware phone fine now.
    Obviously, this is not an ideal solution. So why does the phone client not connect to the hardware phones without the PBX delivers audio box ticked?
    10,360
    226
    Do you have two instances of extension 202?
    I see Extn:202: new contact is registered. Contact(s): [sip:202@192.168.1.125:64355
    Yet...the call in the log is From: Extn:202 ("James Martin" <sip:202@192.168.1.52:5060>)
    In the end the call is terminated: Cause: CANCEL from 192.168.1.125:64355 , the IP not even placing the call.
    So, I'm a bit confused.
  3. opalbiz
    Feb 24, 2015
    I did have 2 phones, 1 3cx softphone and a hardware desk phone. I unprovisioned the hardware phone in favor of exclusively using the softphone.
    192.168.1.52 is the IP of the pbx
    192.168.1.125 is the IP of my computer (3cx client)
  4. IliasL_3CX
    3CX Support
    Jun 2, 2014
    74
    Hi there,
    Did you provision the 3CX Phone clients with the welcome email or manually ?
    Best Regards
