3Cx Windows headset?
Discussion in 'Windows' started by CookChen, Mar 30, 2015.
  1. CookChen
    Mar 30, 2015
    What headset do you guys recommend for 3cx Windows? My IT guy recommended this:
    http://headsetplus.com/product1756/product_info.html
    any experience with this headset?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Just make sure the headset is supported checking the list of supported devices on http://www.3cx.com/support/
