3CX Windows Phone & Headsets
Discussion in '3CX Phone System - General' started by bkit, Sep 7, 2013.
  1. bkit
    Sep 7, 2013
    Just upgraded to V12 and we are using the 3CX phone in SIP mode but we cannot get our Jabra headsets to work, is there anywhere we can choose what microphone and speaker to use ?
    Craig
  2. rogueblackburn
    Aug 11, 2013
    42
    3CX Phone uses Windows audio devices. What ever your active audio device for Windows is set to gets used by the softphone.
  3. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    That infers that whatever your default playback and recording device is for Windows.. is that 3CX Phone will use. There are no choices in the application anymore.. nor will it use the default recording/playback communications devices as one might otherwise expect.
    Will that change on the next update? Stay tuned.
  4. aerocom
    Jul 29, 2008
    15
    I have just installed the latest version to find the same issue. The Jabra software (latest version) does not seem to identify the V12 Softphone now. Also there appears to be no way to set the audio devices with this version in the way you could with v6.
    Any update on this?
    Darren
  5. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    Hi all,
    You can still use your Jabra headsets but the answer/end call button on the headsets will not be functional. If you have any further questions or inquiries please feel free to ask.
    Regards
  6. pacific
    Oct 24, 2008
    Not having a preference button on the new phones is a deal killer! I have several call centers that use 3cx phones for windows and use headsets for calls and speakers for training (they record and review calls) and on breaks. This downgrade is preventing me from the upgrade. I'm not the only one who is complaining about it. Even I have reverted back to version 11 due to this and a problem I'm having dialing out with Outlook and drag and drop functionality. When do we get a fix?
  7. ian.watts
    Apr 8, 2011
    532
    It would seem the only viable workaround would be to keep 3CX Phone v6 installed and configured, and use the v12 in CTI until such time of a new release and hopefully these options availed again.
  8. aerocom
    Jul 29, 2008
    15
    Hi Andreas,
    Thanks for the reply. Can you advise if support for Jabra/Platronics headsets will be re-introduced into the softphone at some stage or if this has been removed permanently?
    Darren
  9. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Hi All
    The current release uses the primary windows selected audio device.
    Next update is going to have the ability to select the device for Microphone, Speaker and ringing. This will be in 1-2 weeks time. For now the primary selected device is used.
    Re jabra and plantronics. They can still work - as normal audio devices. The answer button is not available in V12. You can go ahead and contact Jabra. We had dropped support for plantronics a very long time ago.
    Both headsets will still work when it comes to audio. The answering button will not work.
    We had to remove this support because of their management decisions. We are very sorry for this.
  10. kbrv
    May 15, 2013
    24
    Hi, so what brand of headsets to support the use of the button ?
  11. haywardi
    Feb 27, 2011
    84
    Another customer who would appreciate knowing what wireless headset will work with call answer on the headset?
