3CX windows phone XP support
Discussion in '3CX Phone System - General' started by 805tech, Aug 30, 2013.
  1. 805tech
    Aug 30, 2013
    39
    Just wanted to know if you guys have looked into this and see if you guys going to fix the problem or have XP not supported at all?
    10,848
    299
    I suspect that any new version that currently doesn't work on XP, won't be modified to work. 3CX, like Microsoft wants everyone to "move along". It's understandable, seeing as, I'm sure, it takes more time and effort to make a product backwards compatible. Given that XP won't be having any updates after April 8th of next year, the feeling is probably that many users, especially business, will be "encouraged" to update before then.
    In other words...I wouldn't hold my breath if I were you.
  3. bardissi
    bardissi Member
    Jan 31, 2012
    318
    XP support was dropped once Windows 8 and Server 2012 support was added.
    It will not come back.
    Upgrade your OS!
  4. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    The new version of 3CX phone is now working at XPSP3, WIn2008R2 and Win2012.
  5. bardissi
    bardissi Member
    Jan 31, 2012
    318
    3CX Manual - New Version.. 12 ... Page 16
    NO WINDOWS XP SUPPORT
    http://www.3cx.com/manual/3CXPhoneSystemManual12.pdf
  6. rogueblackburn
    Aug 11, 2013
    42
    "Not Supported" does not mean not working, just don't expect any one from 3CX to answer any questions :) - however you will probably spend more time with work-arounds and unnessecary support to the users, than the cost of an upgrade to W7
