3cx with analog DID
Discussion in '3CX Phone System - General' started by jackd, Apr 6, 2008.
  1. jackd
    Apr 6, 2008
    I decided to try the free version of 3cx last week, I'm very impressed with the product so far. I'm not sure how to make it work with our analog DID trunk we currently have. I believe I'll need an adapter like Multitech's Multivoip MVP's that support DID trunks, is that correct? Are there any other gateways that support DID's?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Using Multitech call-finder 220 should be OK. Because, it can support analog DID start "wink start/delay dial or immediate start".
    Analog DID trunk line -> Multitech call-finder 220 ->FXO or FXS gateway -> 3CX BOX ->softphone or hardphone
    It works. However, it is very expensive analog DID to VoIP solution.
    - incoming calls only
    - No caller ID
    - No calling ID
    Please consider to change analog DID to digital PRI or BRI line instead.
  3. jackd
    Apr 6, 2008
    Are there any other equipment options? Would the MVP130/210/etc work? It appears they support analog DID. Are there any other vendors?
    Switching to BRI/PRI at this time is not feasable. Our existing PBX will not support these lines. If I do decide to use 3cx I want to remain with a configuration that is easily changed back to our existing PBX, if for some reason the 3cx implementation doesn't work as planned.
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    We also try to find SIP gateways for support analog DID line. But not luck. Even Multitech call-finder 220 support analog DID line. However, it cannot direct communicate via TCP/IP to SIP PBX.
    Analog DID trunk line -> Multitech call-finder 220 ->FXO or FXS gateway(3CX supported) -> 3CX BOX ->soft phone or hard phone
    ----------------------->analog------------------------>anaglog----------------------------------->TCP/IP----->TCPIP
    The above setting just for incoming calls ONLY. You also in need to arrange the SIP gateway for extensions issue calls to PSTN.
    We also try Multitech call-finder 220. But now we already put it inside its box. And put it back to store room. Since we are using T1/PRI/ISDN line instead.
    We cannot found other then Multitech call-finder 220 for analog DID to FXO/FXS.
