3CX with Cisco 7931 phone
Discussion in '3CX Phone System - General' started by Michael69, Jan 4, 2016.
  1. Michael69
    Jan 4, 2016
    3CX supports Cisco Phone Type 7940,7941,7960,7961.
    is it possible to use a cisco phone 7931G
  2. Aram
    Aram Support Team
    May 7, 2012
    124
    23
    As you correctly wrote cisco 7931 model is not supported by 3CX, so we can't guarantee that everything will work fine, but you can try it on your side.
    To test the provisioning and functionality you need to do the following steps:
    1. Sure that phone using FW for SIP and not SCCP;
    2. follow the steps described here: http://www.3cx.com/sip-phones/cisco-7940g-7960g/ and just during the provisioning choose cisco 7941. The config file will be generated and you will be able to see is it possible to provision the 7931 with existed provisioning template.
    Hope it will help you.
  3. Michael69
    Jan 4, 2016
    Hi Aram,
    thanks for help.I could provision the Cisco 7931 phone.
  4. Paresh Vaghji
    Jan 25, 2017
    Hi I am struggling to provision my 7931G
    I have the correct firmware but I think I am missing something. I managed to get the name showing up. Also I was able to call that phone. However I was not able to call from it.
    Could you send me your XML for this so I can compare it.
