3cx with Grandstream gxp 1450 first call works then nothing
Discussion in '3CX Phone System - General' started by jeff yager, Jul 13, 2015.
  1. jeff yager
    Oct 10, 2012
    17
    Using a GXP1450 that worked up until today. No changes made.
    First inbound or outbound call works fine. All calls following do not even get to pbx. phone just sits and does nothing.
    Inbound calls to this phone will just time out and go to voicemail.
    wireshark shows nothing. The phone is not even trying to make a call after the first call.
    Any Ideas?
  2. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    Re: 3cx with "Unsupported IP Phone" gxp 1450 first call work
    Hi, Have you tried to re- provision the phone?
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    Assuming the phone is registered, look at the IP address and ensure that it is not in use by another device. Look at the IP on the phone and then disconnect it and try to ping it. It there is a response, then another device also is using that IP.
