3cx with IP DECT for konftel
Discussion in '3CX Phone System - General' started by tlachaus, Oct 30, 2016.
  1. tlachaus
    Feb 11, 2016
    20
    Anyone have a provisioning template for a Konftel IP DECT?
  2. aberry
    aberry New Member
    Jan 13, 2015
    119
    7
    Not officially supported, so I just provision my Konftels manually. I did recently find out that the Snom M DECT base accepts connections from the Konftel 300wX units, and can be provisioned from 3cx v15. Pretty good chance that the built in Snom provisioning template would work with a Konftel IP Dect unit, but probably not the 300IP.
