3CX with ISA 2006
Discussion in '3CX Phone System - General' started by rizzz, Aug 24, 2009.
  1. rizzz
    Jun 25, 2009
    29
    Firstly, sorry for my bad english.
    We are installing in our office a 3CX system.
    And the problem is that we have in our system an ISA server so our VoIP line can't work.
    And the solution i've done to solve this problem is to put the 3CX server out of the domain and enable the 3CX tunnel.
    But unfortunately this technics doesn't work.
    Can anyone tell me how he does use to use 3CX with isa?
    And do you know what's wrong with what i do?
    Is it possible to disable the firewall of isa and enable proxy of isa? cause i'm very bad at isa.
      File size:
      14.3 KB
      1,956
  2. comresource
    comresource Member
    May 22, 2009
    303
    We use ISA as a back-end firewall/proxy/reverse-proxy. ISA server makes a good proxy and firewall but is not so good at NAT/PAT. If you already have an edge router/firewall doing NAT/PAT you can simple change the network relationship in ISA from 'NAT' to 'route' under 'Configuration>Networks>Network Rules' Then you can create the appropriate firewall rules for 3CX
  3. meshad
    Aug 5, 2009
    41
    im also using with ISA 2006. its working this method
    Create rules under computer sets (see the image)
  4. rizzz
    Jun 25, 2009
    29
    Thanks for all your answers.
    I was trying to do these but when i launch the firewall checker it gives me this:
    3CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved.
    <09:27:13>: Phase 1, checking servers connection, please wait...
    <09:27:13>: Stun Checker service is reachable. Phase 1 check passed.
    <09:27:13>: Phase 2a, Check Port Forwarding to UDP SIP port, please wait...
    <09:27:33>: UDP SIP Port is set to 5060. NO RESPONSE received. Phase 2a check FAILED.
    Application exit code is -2
    Do you know what is wrong?
  5. rizzz
    Jun 25, 2009
    29
    I'm still new with ISA so i think it's a problem of parameter of ISA.
    Can you tell me exactly the step i must follow to configure ISA?
    I just know i must open these ports: 5090(tcp) , 5060(tcp & udp), 3478(stun), 90xx.
    Best regards,
  6. meshad
    Aug 5, 2009
    41
    Can u provide me these information
    1. Type of SIP client that your using ?
    2. ITSP (VoIP provider) name?
    3. are u able to ping to public IP address from your local LAN?
  7. rizzz
    Jun 25, 2009
    29
    I don't know exactly what is a SIP client but i use 3CX softphone and linksys spa922 hardphone. It's not a problem of sip client because there is no problem when i use pstn line.
    It's not a problem of voip provider because i've tried to take off the ISA server, then the voip line was working well.
    My voip provider is not on the 3cx list.
    yes
  8. rizzz
    Jun 25, 2009
    29
    I read in an another post that after creating the rules i must create a publishing rules for the 3Cx server.
    Is it a good idea to create that? :?:
    Please help :cry:
  9. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,926
    241
    ISA server is not a good firewall for any VoIP application.
    You can see our wiki for more information
    http://wiki.3cx.com/documentation/networking/isa-server
  10. rizzz
    Jun 25, 2009
    29
    Hi Nick,
    Thanks for answering.
    I know ISA is not a good firewall for VoIP but i can't tell my boss to buy an another firewall.
    That's why on my first post i was posting an architecture on wich i place the 3cx server before the ISA. :idea:
    Do you think this architecture can work?
  11. meshad
    Aug 5, 2009
    41
    i think this will help on your issue.
    http://www.ocg.ca/generationd/Pages/Downloads/Files.php?downloads=windows
  12. rizzz
    Jun 25, 2009
    29
    Thanks meshad, :p
    I will try it.
    They give a solution for it but they say it works ISA 2000 and 2004.
    Do you know if it works with ISA 2006?
  13. meshad
    Aug 5, 2009
    41
    I am also using ISA 2006.
    My VOIP Gateway is firewalled by ISA and 3CX out of ISA. i can able to call to any SIP client from GSM/PSTN via gateway but having audio problem with receving to GSM/PSTN via gateway.
