3CX with NEC Aspire
Discussion in '3CX Phone System - General' started by shy, Jan 9, 2008.
  1. shy
    shy
    Jan 9, 2008
    I am from UAE, VoIP calls are ban here, I am using LowrateVoip to make cheap international calls, i am using one VPN service, I could register 3CX to LowrateVoip sever through my VPN, without VPN it doesn't get register.
    I got NEC ASpire SIP compatible telephone system in the office, I configured my lowrate Voip account in that but that doesn't work, is there any ways that I can link my telephone system with 3CX ?
    Appreciate ur answer
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    If its a SIP Phone it should work. so all you have to do is create an extension on 3CX and configure it on the phone(dont know the phone so no details here). But there should no problem with it..
    Cheers
