3CX with Netsuite
Discussion in 'CRM / Helpdesk / App Integration' started by Maarten, Aug 29, 2017.
  1. Maarten
    Aug 9, 2017
    41
    Could not find anything on the forums and was wondering if anyone has been able to integrate 3CX with Netsuite?
    We are currently running that and i am looking in any possibility to implement the two together.
    Regards,
    Maarten
    usat likes this.
  2. Mike Cartwright
    Jun 3, 2017
    26
    You might want to check a 3rd party CTI like Tenfold, Maarten. Tenfold's features include click-to-dial, automatic call log, easy task creation, a call analytics dashboard, and more. You can view 3cx and Netsuite's integration via Tenfold here: https://www.tenfold.com/integrations/netsuite/threecx
