3CX with OBI 110 as PSTN gateway
Discussion in '3CX Phone System - General' started by Ash91, Dec 7, 2015.
  1. Ash91
    Dec 7, 2015
    7
    Hello everyone,
    I have been struggling to place outbound calls from yealink IP phones. First I installed 3CX software in my windows and added a PSTN gateway & gave the host address as my OBI's web interface. And I managed to register OBI with 3CX. Now comes the hard part, where i can receive calls from outside and at the same time i can call to the other extensions within the network but unable to place outbound calls. I seriously have tried my best by altering everything which is in the internet but still the problem exist. Any help woul;d be much appreciated. This is the error message that i get from server log,
    7-Dec-2015 23:25:26.285 [CM503003]: Call(C:5): Call to <sip:66627128@192.168.1.70:5060> has failed; Cause: 404 Not Found/INVITE from 192.168.1.70:5060
    07-Dec-2015 23:24:27.716 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.1.70:5061 tid=-5452ebc4 Call-ID=083b7717@192.168.1.70:
    REGISTER sip:192.168.1.99:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.70:5061;branch=z9hG4bK-5452ebc4;rport=5061
    Max-Forwards: 70
    Contact: <sip:90001@192.168.1.70:5061>;expires=60;+sip.instance="<urn:uuid:00000000-0000-0000-0000-9cadef0141d1>"
    To: <sip:90001@192.168.1.99>
    From: <sip:90001@192.168.1.99>;tag=SP21514ba237f45cc9a
    Call-ID: 083b7717@192.168.1.70
    CSeq: 51324 REGISTER
    Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER, UPDATE
    Proxy-Authorization: DIGEST algorithm=MD5,nonce="414d535c0c767bfb61:4400d668f273a07cddadfce596d15a79",realm="3CXPhoneSystem",response="c3c40b74fab5c9de59d2ec71c4490ad9",uri="sip:192.168.1.99:5060",username="90001"
    Supported: replaces
    User-Agent: OBIHAI/OBi110-1.3.0.2872
    Content-Length: 0
    ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07-Dec-2015 23:23:57.498 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.1.70:5061 tid=-53392b6d Call-ID=1acde7a7@192.168.1.70:
    Via: SIP/2.0/UDP 192.168.1.70:5061;branch=z9hG4bK-53392b6d;rport=5061
    Max-Forwards: 70
    Call-ID: 1acde7a7@192.168.1.70
    CSeq: 2129 REGISTER
    Proxy-Authorization: DIGEST algorithm=MD5,nonce="414d535c0c767bdd06:46a6953a9a095ed29f325305ceaba904",realm="3CXPhoneSystem",response="e1c3b5625274a7d9837194601dd54dc9",uri="sip:192.168.1.99:5060",username="90001"
    Supported: replaces
    Content-Length: 0
    07-Dec-2015 23:23:27.280 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.1.70:5061 tid=-5d2b1a5f Call-ID=5d3c2d31@192.168.1.70:
    Via: SIP/2.0/UDP 192.168.1.70:5061;branch=z9hG4bK-5d2b1a5f;rport=5061
    Max-Forwards: 70
    Call-ID: 5d3c2d31@192.168.1.70
    CSeq: 4326 REGISTER
    Proxy-Authorization: DIGEST algorithm=MD5,nonce="414d535c0c767bbf52:940c3f08145d75b519a2bea3641e834f",realm="3CXPhoneSystem",response="3277123839b2e05ee4bd1569ec5afaa4",uri="sip:192.168.1.99:5060",username="90001"
    Supported: replaces
    Content-Length: 0
    07-Dec-2015 23:22:57.062 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.1.70:5061 tid=-283cfdf1 Call-ID=add11a32@192.168.1.70:
    Via: SIP/2.0/UDP 192.168.1.70:5061;branch=z9hG4bK-283cfdf1;rport=5061
    Max-Forwards: 70
    Call-ID: add11a32@192.168.1.70
    CSeq: 1996 REGISTER
    Proxy-Authorization: DIGEST algorithm=MD5,nonce="414d535c0c767b8279:ef88446f454ea77d61b447b41bb45c16",realm="3CXPhoneSystem",response="1ea65c2c74c01f22b6d950585893fd0e",uri="sip:192.168.1.99:5060",username="90001"
    Supported: replaces
    Content-Length: 0
    07-Dec-2015 23:19:09.969 [Flow] Target endpoint for 66627128 can not be built!
    07-Dec-2015 23:18:09.696 [Flow] Target endpoint for 66627128 can not be built!
    07-Dec-2015 23:17:08.169 [Flow] Target endpoint for 66627128 can not be built!
    07-Dec-2015 23:16:14.273 [Flow] Target endpoint for 66627128 can not be built!
    07-Dec-2015 23:14:56.739 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.1.70:5061 tid=-6323ff59 Call-ID=d2da8ed2@192.168.1.70:
    Via: SIP/2.0/UDP 192.168.1.70:5061;branch=z9hG4bK-6323ff59;rport=5061
    Max-Forwards: 70
    From: <sip:90001@192.168.1.99>;tag=SP22a16a4eb23c2f145
    Call-ID: d2da8ed2@192.168.1.70
    CSeq: 49153 REGISTER
    Proxy-Authorization: DIGEST algorithm=MD5,nonce="414d535c0c7679c046:df0ff68853cec574a9917aeda4b8c4f3",realm="3CXPhoneSystem",response="0fae6e31a628638d13db84475c712efd",uri="sip:192.168.1.99:5060",username="90001"
    Supported: replaces
    Content-Length: 0
    07-Dec-2015 23:14:28.281 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.1.70:5061 tid=-237c5e00 Call-ID=daf2ab4c@192.168.1.70:
    Via: SIP/2.0/UDP 192.168.1.70:5061;branch=z9hG4bK-237c5e00;rport=5061
    Max-Forwards: 70
    From: <sip:90001@192.168.1.99>;tag=SP22fd6b36564aca7e3
    Call-ID: daf2ab4c@192.168.1.70
    CSeq: 5397 REGISTER
    Proxy-Authorization: DIGEST algorithm=MD5,nonce="414d535c0c7679a409:18fefe9f4af1d2974c80a85e4837d295",realm="3CXPhoneSystem",response="9a354ed9df0238b300021a636df0e7f4",uri="sip:192.168.1.99:5060",username="90001"
    Supported: replaces
    Content-Length: 0
    07-Dec-2015 23:13:58.060 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.1.70:5061 tid=-6cee2a13 Call-ID=6d030847@192.168.1.70:
    Via: SIP/2.0/UDP 192.168.1.70:5061;branch=z9hG4bK-6cee2a13;rport=5061
    Max-Forwards: 70
    Call-ID: 6d030847@192.168.1.70
    CSeq: 37482 REGISTER
    Proxy-Authorization: DIGEST algorithm=MD5,nonce="414d535c0c76798564:0ee9bf683d02c4f0344cd925b8ab694e",realm="3CXPhoneSystem",response="5fcb0e2db5c1d21d7cde8d9dcbf62a5e",uri="sip:192.168.1.99:5060",username="90001"
    Supported: replaces
    Content-Length: 0
    07-Dec-2015 23:13:27.840 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.1.70:5061 tid=-4c052743 Call-ID=742cbca4@192.168.1.70:
    Via: SIP/2.0/UDP 192.168.1.70:5061;branch=z9hG4bK-4c052743;rport=5061
    Max-Forwards: 70
    Call-ID: 742cbca4@192.168.1.70
    CSeq: 47207 REGISTER
    Proxy-Authorization: DIGEST algorithm=MD5,nonce="414d535c0c76796734:e78be0c6ec28dd205a1a1ac52904a36d",realm="3CXPhoneSystem",response="0a1e110f7031ed6798b522a125e12b42",uri="sip:192.168.1.99:5060",username="90001"
    Supported: replaces
    Content-Length: 0
    07-Dec-2015 23:13:23.567 Set log verbosity to MaxLevel = 2, Severity mask = 7
    07-Dec-2015 23:13:23.519 Supported Mime Type added:MESSAGE(x-chat/control)
    07-Dec-2015 23:13:23.518 [CM506005]: Public IP=37.210.189.47 is used for WAN communications through local interface with IP=192.168.1.99
    07-Dec-2015 23:13:22.758 [EC200002]: Media server is connected:
    application:DESKTOP-P61MJEU:0/MediaServer
    local:127.0.0.1:5482
    remote:127.0.0.1:62892
    07-Dec-2015 23:13:22.451 [CM501006]: Default Local IP address: [192.168.1.99]
    07-Dec-2015 23:13:22.443 [CM501002]: Version: 14.0.45008.0
    07-Dec-2015 23:13:22.443 [CM501001]: Start 3CX PhoneSystem Call Manager
    07-Dec-2015 23:13:22.443 [CM501010]: License Info: Load Failed - 26
    07-Dec-2015 23:13:22.333 Set tenant started signal for MediaServer
    07-Dec-2015 23:13:22.253 [CM501007]: *** Started Calls Controller thread ***
    10,362
    227
    I'm seeing two port numbers (5060 and 5061) associated with IP 192.168.1.70 Are you using two devices on the Obi?
    Don't forget that you must specify the correct port number in the 3CX trunk settings to be used in outbound calls.
    While I've had an Obi for quite some time, I have not attempted any outbound calls over it. I used to use it for incoming (only) PSTN and now for Google Voice incoming only. I haven't had the patience to sit down and figure the way they do out their dialling plans.
  3. Ash91
    Dec 7, 2015
    7
    Thanks for the reply. I just use one OBI device. And i have got the connection from LINE port of the OBI. I dont know why i can receive only incoming calls? I cannot figure out the problem.
  4. Ash91
    Dec 7, 2015
    7
    Hi please check the attached image of the gateway settings.
  5. leejor
    10,362
    227
    The 3CX settings for the gateway show that outgoing calls will route to it's IP and port 5060. I seem to recall that the Obi is similar to the Cisco SPA-3102 in that there is an FXS and FXO portion and each use a separate local port. If the FXO circuit is assigned port 5061 on the Obi, then 3CX has to be told to use that port for outbound calls.
