3CX with Patton 4114 - 4 x FXO
Discussion in '3CX Phone System - General' started by bob21, Apr 24, 2008.
  1. bob21
    Mar 17, 2008
    I have 3CX free version running under Win2k, reloaded under new download yesterday, interfaced to a Patton 4114. 3 x extensions - 2 x IP phones, 1 x ATA. As far as I can tell all extensions are configured in the same way.
    Extn to Extn calls are all fine - so all phones registered to 3CX correctly and no network issues
    Making an external call on an IP phone the call connects with no problem - so the Patton seems to be registered / configured correctly to the 3CX
    However, making a call via the ATA extension results in no connection - busy tone
    Firewall should not be an issue as the calls are to a regular PSTN line - not a SIP provider.
    Have had this problem for a week or so - hence the uninstall / reboot / install new download.
    Only port 0 has an external line connected for testing.
    Call from ATA Log is :-
    13:57:07.390 Call::Terminate [CM503008]: Call(3): Call is terminated
    13:57:07.328 Call::RouteFailed [CM503014]: Call(3): Attempt to reach [sip:02083506158@192.168.1.100] failed. Reason: Unsupported Media Type
    13:57:07.312 CallLeg::eek:nFailure [CM503003]: Call(3): Call to sip:1886602083506158@192.168.1.99:5060 has failed; Cause: 415 Unsupported Media Type; from IP:192.168.1.99:5060
    13:57:07.171 CallLeg::eek:nFailure [CM503003]: Call(3): Call to sip:1886602083506158@192.168.1.99:5066 has failed; Cause: 415 Unsupported Media Type; from IP:192.168.1.99:5066
    13:57:07.000 CallLeg::eek:nFailure [CM503003]: Call(3): Call to sip:1886602083506158@192.168.1.99:5064 has failed; Cause: 415 Unsupported Media Type; from IP:192.168.1.99:5064
    13:57:06.859 CallLeg::eek:nFailure [CM503003]: Call(3): Call to sip:1886602083506158@192.168.1.99:5062 has failed; Cause: 415 Unsupported Media Type; from IP:192.168.1.99:5062
    13:57:06.718 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(3): Calling: PSTNline:10002@[Dev:sip:10002@192.168.1.99:5062, Dev:sip:10003@192.168.1.99:5064, Dev:sip:10004@192.168.1.99:5066, Dev:sip:10001@192.168.1.99:5060]
    13:57:06.625 CallCtrl::eek:nIncomingCall [CM503001]: Call(3): Incoming call from Ext.104 to [sip:02083506158@192.168.1.100]
    Call from IP phone log is :-
    13:59:46.390 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:888@192.168.1.100:5060 with contact sip:888@192.168.1.100:5100;user=phone
    13:59:45.437 Call::Terminate [CM503008]: Call(4): Call is terminated
    13:59:45.375 Call::Terminate [CM503008]: Call(4): Call is terminated
    13:59:45.328 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone
    13:59:26.484 CallCtrl::eek:nLegConnected [CM503007]: Call(4): Device joined: sip:10001@192.168.1.99:5060
    13:59:26.468 CallCtrl::eek:nLegConnected [CM503007]: Call(4): Device joined: sip:101@192.168.1.21:5060;transport=udp
    13:59:21.578 Line::printEndpointInfo [CM505002]: Gateway:[Patton4FXO] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Patton SN4114 JO EUI MxSF v3.2.8.45 00A0BA038BB4 R4.2 2007-09-19 H323 SIP FXS FXO] Transport: [sip:192.168.1.100:5060]
    13:59:21.343 CallLeg::eek:nFailure [CM503003]: Call(4): Call to sip:1886602083506158@192.168.1.99:5066 has failed; Cause: 502 Bad Gateway; from IP:192.168.1.99:5066
    13:59:21.171 CallLeg::eek:nFailure [CM503003]: Call(4): Call to sip:1886602083506158@192.168.1.99:5064 has failed; Cause: 502 Bad Gateway; from IP:192.168.1.99:5064
    13:59:20.968 CallLeg::eek:nFailure [CM503003]: Call(4): Call to sip:1886602083506158@192.168.1.99:5062 has failed; Cause: 502 Bad Gateway; from IP:192.168.1.99:5062
    13:59:20.828 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(4): Calling: PSTNline:10002@[Dev:sip:10002@192.168.1.99:5062, Dev:sip:10003@192.168.1.99:5064, Dev:sip:10004@192.168.1.99:5066, Dev:sip:10001@192.168.1.99:5060]
    13:59:20.703 CallCtrl::eek:nIncomingCall [CM503001]: Call(4): Incoming call from Ext.101 to [sip:02083506158@192.168.1.100]
    All advice welcome - thanks in advance
    Cheers
    Bob
