3CX with Patton SmartNode SN4118/4JS4JO/EUI
Discussion in '3CX Phone System - General' started by san_narula, May 28, 2015.
  1. san_narula
    May 13, 2015
    10
    Can someone tell me if 3CX has a provisioning template for Patton SmartNode SN4118/4JS4JO/EUI, if not how difficult is it to create it manually. If it is too difficult, what are my other options?
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    388
    52
    3CX doesn't have templates for Patton devices that are part FXO and part FXS. You can provision one or the other through 3CX and the rest manually. Contact Patton for help they have free tech support and might have their own template you can use.
  3. san_narula
    May 13, 2015
    10
    So I can use two separate gateways for fxo and fxs and use 3cx templates?
    I also wanted to confirm that the gateway will connect to the switch/router and not to the 3CX server directly, is it right?
  4. CentrexJ
    CentrexJ Member
    May 5, 2009
    388
    52
    Correct if you have two physical patton boxes one for fxs and one for fxo the 3CX templates are built for those only.
    The patton plugs into your switch and communicates over ethernet.
