3CX with Skype Gateway problem
Discussion in '3CX Phone System - General' started by pstmg, Aug 12, 2014.
  1. pstmg
    Dec 9, 2012
    49
    Hello all
    I don't know what is happening but for some reason when a call arrives from skype it's delivered to a remote extension (outside lan) and when the call is picked up it disconnects at the same time. Bellow you can see the 3CX system log, so what's wrong here ?
    Regards
    Paulo
    12-08-2014 13:08:45.790 Leg L:1274.2[Extn] is terminated: Cause: BYE from PBX
    12-08-2014 13:08:45.790 [CM503008]: Call(C:1274): Call is terminated
    12-08-2014 13:08:45.790 Leg L:1274.1[Line:10005<<pstmg] is terminated: Cause: BYE from 127.0.0.1:6060
    12-08-2014 13:08:45.493 [CM503007]: Call(C:1274): Extn:111 has joined, contact <sip:111@remote-ip.com:51079>
    12-08-2014 13:08:45.493 [CM503007]: Call(C:1274): Line:10005<<pstmg has joined, contact <sip:10005@127.0.0.1:6060>
    12-08-2014 13:08:45.493 L:1274.2[Extn] has joined to L:1274.1[Line:10005<<pstmg]
    12-08-2014 13:08:44.337 [CM503025]: Call(C:1274): Calling T:Extn:111@[Dev:sip:111@remote-ip.com:51079] for L:1274.1[Line:10005<<pstmg]
    12-08-2014 13:08:44.290 [CM503027]: Call(C:1274): From: Line:10005<<pstmg ("Paulo Gonçalves" <sip:pstmg@pbx-ip.com:5060>) to T:Extn:111@[Dev:sip:111@remote-ip.com:51079]
    12-08-2014 13:08:44.290 [CM503004]: Call(C:1274): Route 1: from L:1274.1[Line:10005<<pstmg] to T:Extn:111@[Dev:sip:111@remote-ip.com:51079]
    12-08-2014 13:08:44.290 [CM505002]: Gateway:[skype] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:10005@127.0.0.1:5060]
    12-08-2014 13:08:44.290 [CM503001]: Call(C:1274): Incoming call from Line:10005<<pstmg to <sip:111@192.168.1.65:5060>
    12-08-2014 13:08:44.290 Line limit check: Current # of calls for line Lc:10005(@skype[<sip:10005@127.0.0.1:6060>]) is 1; limit is 1
    12-08-2014 13:08:44.290 [CM503012]: Inbound office hours rule (unnamed) for 10005 forwards to DN:111
    10,760
    286
    The log doesn't really give a clear reason as to why the call is dropped. You might try looking at the Verbose settings to see if there is any additional information.
    When did this start? Were any changes made on the system/network/Skype program, or at the location of the remote extension?
    If you direct a Skype call to a local extension, does the call drop? What about a call directed to another remote extension, different location? What about a "regular" outside line directed to the same outside extension, does that drop. Have you replaced the remote extension?
    You see where I'm going with this...By process of elimination, you should be able to determine if it is the Skype gateway, 3CX PBX, the remote extension/network, or something on the local network, that is causing this. If it has worked well up to this point, then something has changed.
  3. pstmg
    Dec 9, 2012
    49
    Thanks leejor for your reply. I will check the points you mentioned and post the results later on
    Regards
    Paulo
  4. pstmg
    Dec 9, 2012
    49
    well yesterday I saw it working but after a while (3 hours or more) the problem came again. it seems that the problem is one of the routers that closed Voip ports and leads to a call disconnecting problem after pickup.
    Can this problem be fixed ?
    Regards
    Paul
