3CX with Voicepulse
Discussion in '3CX Phone System - General' started by laristech, Jan 20, 2011.
  1. laristech
    Jan 15, 2011
    Hello All,
    I am coming from Trixbox with Broadvoice and I am trying to configure this 3CX system. I was able to make it work using the third party config for broadvoice but I am having issue trying to make it work with Voicepulse. I want to go with voicepulse because they allow outbound caller ID.
    This is what I have done so far...
    Installed the third party config file in the correct location.
    Setup voicepulse on the system and it registers to voicepulse.
    I am unable to get inbound calls or place any outbound calls. VoicePulse wont give me support because the system is not made by them, but they said they do support having the system on their network.
    Any help would be great!
