3CX wrong identification with Panasonic KX-TEM824 ???
Discussion in '3CX Phone System - General' started by pr0t31n_w13, Jun 19, 2008.
  1. pr0t31n_w13
    Jun 19, 2008
    Heloo...
    Sorry for bad english, and hope there is someone there can help me..
    I'm using 3CX Phone System Version5.0.3790.0; and LinkSys SPA 2102... work fine with x-lite softphone and direct phone (single line)
    then i connect SPA2102 with Panasonic PBX KX-TEM824
    when i call FROM direct phone (attach at SPA2102) or xlite TO PBX KX-TEM824.. everything is OK..
    BUT when i call FROM PBX KX-TEM824 TO X-lite softphone ID or direct phone (LINKSYS SPA2102) .. 3CX Ph System identify wrong ID..
    example
    x-lite phone id is 100@serverip
    SPA2102 directphone ID is 200@serverip
    SPA2102 -PBX KX-TEM824 ID- is 300@serverip
    when from 300@serverip call to 200@serverip ; 3cx phone system identify destination is 2000@serverip where that id is not found, so call can not establish.
    when from 300@serverip call to 100@serverip ; 3cx phone system identify destination is 1000@serverip where that id is not found, so call can not establish.
    sometimes wrong identify destination is 1@serverip, or 20000@serverip where all ID is not register, so call can establish.
    but when i make call from xlite or directphone to PBX, everything is fine....
    how to solve that problem??
    thanks a lot everyone...
    660 2008-06-19 09:58:25 900 2222 No Answer <--- wrong identify ID (the correct ID is 222)
    671 2008-06-19 11:22:58 600 8 No Answer <--- wrong identify ID (the correct ID is 800)
    672 2008-06-19 11:26:13 101 600 No Answer
    673 2008-06-19 11:26:21 101 700 Answered 00:00:13
    674 2008-06-19 11:26:39 101 700 Answered 00:00:16
    675 2008-06-19 11:26:59 101 600 Answered 00:00:13
    676 2008-06-19 11:27:56 800 1 No Answer <------ worng (the correct ID is 100)
    677 2008-06-19 11:28:13 800 222 Answered 00:00:38
    678 2008-06-19 11:32:53 800 222 Answered 00:01:20
    679 2008-06-19 11:36:57 222 900 Answered 00:00:53
    680 2008-06-19 11:37:27 600 8 No Answer <---- wrong (the correct ID is 800)
  2. pr0t31n_w13
    Jun 19, 2008
    09:02:30.062 Call::Terminate :[CM503008]: Call(3): Call is terminated
    09:02:30.046 Call::RouteFailed :[CM503014]: Call(3): Attempt to reach [sip:9000@192.168.0.50] failed. Reason: Not Found
    09:02:30.046 CallCtrl::eek:nSelectRouteReq :[CM503013]: Call(3): No known route to target: [sip:9000@192.168.0.50]
    09:02:30.015 CallCtrl::eek:nIncomingCall :[CM503001]: Call(3): Incoming call from Ext.222 to [sip:9000@192.168.0.50]
    failed. Reason: Not Found.
    wrong identification.. it haved to be 900@192.168.0.50 ; why 3CX identify as 9000@192.168.0.50 ???
    or this problem occur because Panasonic PBX TEM824 ???
    can anyone help ?
    thanks a lot!
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    In this case PBX doesn't "identify" anything. It just prints what it get in SIP message.
  4. pr0t31n_w13
    Jun 19, 2008
    thanks for reply archie...
    so is this bug from 3CX or LinkSys SPA2102 ???
    yesterday i search update firmware of LinkSys and found the new one, so i update all my linksys spa2102.
    problem still occur..
    anyway... Thanks a lot
    and still waiting for help...
    07:46:35.406 Call::Terminate :[CM503008]: Call(8): Call is terminated
    07:46:35.390 Call::RouteFailed :[CM503014]: Call(8): Attempt to reach [sip:60000@192.168.0.50] failed. Reason: Not Found
    07:46:35.390 CallCtrl::eek:nSelectRouteReq :[CM503013]: Call(8): No known route to target: [sip:60000@192.168.0.50] <--- wrong identify
    07:46:35.359 CallCtrl::eek:nIncomingCall :[CM503001]: Call(8): Incoming call from Ext.333 to [sip:60000@192.168.0.50] <--- wrong identify
    (the right sip is 600@192.168.0.50)
    07:40:53.296 Call::Terminate :[CM503008]: Call(3): Call is terminated
    07:40:49.046 CallCtrl::eek:nSelectRouteReq :[CM503004]: Call(3): Calling: Ext:222@[Dev:sip:222@192.168.0.33:5060] <----- correct identify
    07:40:48.968 CallCtrl::eek:nIncomingCall :[CM503001]: Call(3): Incoming call from Ext.333 to [sip:222@192.168.0.50] <----- correct identify
    07:40:19.703 Call::Terminate :[CM503008]: Call(2): Call is terminated
    07:40:19.687 Call::RouteFailed :[CM503014]: Call(2): Attempt to reach [sip:2222@192.168.0.50] failed. Reason: Not Found
    07:40:19.687 CallCtrl::eek:nSelectRouteReq :[CM503013]: Call(2): No known route to target: [sip:2222@192.168.0.50] <--- wrong identify
    07:40:19.640 CallCtrl::eek:nIncomingCall :[CM503001]: Call(2): Incoming call from Ext.333 to [sip:2222@192.168.0.50] <--- wrong identify
  5. archie
    3CX Support
    Aug 18, 2006
    1,299
    Wasn't it clear enough from my comment?
    As I see it - the problem is in DTMF detection between ATA and analogue phone. It seems it doubles digits sometimes. Try to adjust timings in your ATA settings.
  6. pr0t31n_w13
    Jun 19, 2008
    sorry... i try to understand you :) my english is not good enough, and this area (VOIP and PBX) are new for me.
    anyway.. Problem Solved!!
    Change DTMF Playback Level from -16 to 0 ; and DTMF Playback Length from 0.1 to 0.5 ( found solution at another forum that i found at google)
    Thank to you Archie so i can focus at DTMF.. honestly i don't understand at all about VOIP. newbiee
