3cx Yealink Templates
Discussion in '3CX Phone System - General' started by 2nd, Feb 15, 2018.
  1. 2nd
    2nd
    Aug 26, 2015
    Does anyone know what template the Yealink T29G uses?
    I need to edit the template for the call forward to work but there is templates for 3x, 4x, 5x, CP etc but no 2x
  2. GeekSqueak
    Feb 7, 2018
    11
    Check @complex1 's post below. Thanks Complex1.
    PS. We have a fleet of Yealink T20P phones and we had to disable the feature key synchronization setting to get call forward to work on the phones. This may not be the case for newer Yealink phones.
    #2 GeekSqueak, Feb 15, 2018
    2nd likes this.
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    813
    46
    To provision the Yealink T29G please use the yealinkT4x.ph template.
    2nd and GeekSqueak like this.
  4. 2nd
    2nd
    Aug 26, 2015
    Thats exactly what im doing
  5. 2nd
    2nd
    Aug 26, 2015
    Perfect
    Thankyou
  6. GeekSqueak
    Feb 7, 2018
    11
    If anyone is going to use custom templates, for Yealink Phones, please pay close attention to the Yealink specific configuration in the 3CX custom template tutuorial found here:
    https://www.3cx.com/docs/custom-ip-phone-templates/
    Just food for thought,
    GeekSqueak
    YiannisH_3CX likes this.
