Solved 3CX15.5: remove ringgroup name from phone displays
Discussion in '3CX Phone System - General' started by flurk, Feb 15, 2018.
  1. flurk
    Sep 4, 2010
    19
    I'm a home user who switched from 3cxv10 to v15.5 (on Linux).
    A problem that I managed to solve in v10, has come up again and I don't find the solution anymore.
    Incoming calls (through landline) arrive on the "operator's" phone. After a few rings the incoming call is automatically forwarded to a ringgroup named "incoming calls", which rings a number of other telephones in the house.
    On the telephone displays we read now: "Landline incoming: incoming calls".
    How can I remove the name of the ring group "incoming calls" from the phone display?
    I managed to solve this in v10. Now I'm desperately searching in all options but I don't find anything.
    Our telephones are siemens optipoint 410/420
    thank you for your help.
  2. noord
    Nov 25, 2015
    32
    In the management console, go to 'Contacts', click 'Options' and under 'add group, queue or DDI/DID Names to Caller ID' select 'do not add'.
  3. flurk
    Sep 4, 2010
    19
    Thank you. That was what I was looking for.
