3CX_Debian_install_VirtualBox
Discussion in '3CX Phone System - General' started by mixig, Dec 11, 2017.
  1. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    for test purpose i tried to install 3cxDebian (offical 3cx .iso file), when I get prompt choose 1 or 2 (WEB browser or CLI; I choosed Web browser) nothing happend; manual says go to http://IP_address:5015 but nothing is showing up (i put te corectt IP).
    I also tried 127.0.0.1:5015 because VM is on the same host. In CLI status is like in the attach
    Also under the network settings i choose Bridge Adapter (just linke says in the manual):
    https://www.3cx.com/docs/debian-linux-using-virtualbox/
    Am i doing somethnig wrong or?
  2. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    You didn't use the full link including ?v=2
    I just used the CLI. If you're gonna use linux use it like a man.
    strint_echo likes this.
  3. V..
    V..
    Feb 14, 2017
    74
    29
    Hi Mixig,
    I suspect you may have incorrectly configured your virtual adaptor. Also please note that just because a VM may be on the same physical hardware you will not be able to access it via the hosts's loopback interface.
    NickD_3CX likes this.
  4. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,367
    83
    I suspect the same, I think once I tried VirtualBox I had to set Adapter Type to "Bridged Adapter", so essentially the VM got an IP from the DHCP of my router that was though different to that of the Host PC.
