3cx_licence level changes
Discussion in '3CX Phone System - General' started by bijayk2006, Dec 7, 2010.
  1. bijayk2006
    Dec 5, 2010
    If the license level of the 3CX PhoneSystem is changed, will this change a user's capability to answer Queue Calls?
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    HI,
    The 3cx free edition does not allow use of queues, if that is your question, please be more specific if it is not.
  3. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Assuming that you are already using a commercial version of 3CX Phone System, providing you are doing an upgrade on the licence then you won’t lose any call features on 3CX.
    If however you downgrade to a Free Edition, then any features not covered by this edition will not be available.
