3cxBackup.exe does not produce a file
Discussion in '3CX Phone System - General' started by ehrendreich, Apr 27, 2011.
  1. ehrendreich
    Sep 21, 2008
    12
    It would seem that the backup utility is not creating a back up file. It runs and gives no feedback. It just comes back to a command prompt with no response. Any ideas?
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi, can you look in the windows event logs for any errors? and post them here if any
  3. smb1
    smb1 New Member
    Mar 18, 2009
    104
    It sounds like you are trying to run the backup from the command line. Can you provide an example of the switches being used to invoke the program?
  4. davidbenwell
    Apr 27, 2010
    704
    well spotted, did not pick up on this.
    please use the backup / restore tool provided by 3CX
    Start Menu > All Programs > 3CX Phone System > Backup and Restore Tool
