3CXCRM12 deployment options
Discussion in '3CX Phone System - General' started by site, Oct 24, 2013.
  1. site
    Nov 30, 2009
    21
    Is there a way to deploy the 3CXCRM12.exe with options?
    I'm wanting to deploy with Outlook Integration and the TAPI driver.
    I can successfully Extract the files and deploy the .msi's for x86/x64 independently which installs the Outlook Integration, but I'm unable to figure out how to deploy the TAPI portion.
    Any help would be greatly appreciated.
  2. site
    Nov 30, 2009
    21
    Is there nothing on this?
    Are there not options to be able to select by command line or transform file which components of the CRM package get installed?
    3CX, we need help from you on this.... if the options are or aren't there, please respond back with something.
    You want us to upgrade to V12, but you make rollout an unbelievable pain if we can't automate some of this.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,128
    152
    Install on 32 bit - Take the tapi driver from windows\system 32
    Install on 53 bit - take the tapi driver from windows\system 32
    make your own installations. Cannot understand why you need help on this.
    then use regsvr32 commands to register the tapi driver or use standard installer registrations.
    What do you want to do exactly? Why do something duplicate that our installers can already do? You want to deploy via Gpo?
