3cxIVRServer.exe high CPU
amartini
with version 6 installed in my P4 1 gbyte memory, Windows XP pro, I have a problem with 3cxIVRServer.exe that slow down my PC taking the 50-60% of cpu time.
Can you help me, please?
Thank you
Is the computer slowing down, because of it?
Do you have power saving features enabled? If so disable or set to max performance.
I've changed PC with a most powerful, and after the last upgrade to 6.0.644, the IVRSERVER and IVRMEDIA bring the CPU high only for 10 minutes after the start of services.
Good, that looks like "normal" to me.
H.
Getting Started - Admin
Dozer302
Get 3CX - Absolutely Free!
3CX
