3CXIVRServer.exe service crashes leaving silence on IVR
Discussion in '3CX Phone System - General' started by Urbok, Dec 18, 2007.
  1. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    On v5 I've found this service crashed many times. (never happened on super stable v3)
    here the logs:
    Application Error
    Applicazione che ha provocato l'errore 3CXIVRServer.exe, versione 5.0.3648.0, modulo che ha provocato l'errore 3CXIVRServer.exe, versione 5.0.3648.0, indirizzo errore 0x0000c18d.
    Per ulteriori informazioni, consultare la Guida in linea e supporto tecnico all'indirizzo http://go.microsoft.com/fwlink/events.asp.
    Dr Watson
    L'applicazione C:\Programmi\3CX PhoneSystem\Bin\3CXIVRServer.exe ha generato un errore di applicazione. L'errore si è verificato su 12/18/2007 @ 09:56:47.093 Exception c0000005 generata all'indirizzo 0040C18D (3CXIVRServer!MTObjects__MTReferencedTypeBase__MTReferencedTypeBase)
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Hmm..
    Not easy to get this since my Italian knowledge mostly is limited to Pizza. 8)
  3. crsc
    Dec 1, 2007
    28
    The Exception c0000005 is an "access denied error" from the 3CXIVRServer service. This Dr. Watson should be paired with another error. I have seen Event ID 1004 when the IVR server crashes.
    What OS are you running? I seen the error often running XP, not so often with Windows Server 2003; which make me believe that might be the server accessing voice files concurrently. This is just a guess, I don't have source code to prove it.
  4. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    it's an xp pro.
    with v3 ivr nether crashed...
    boh??
