3CXMediaServer crash using voicemail (3CX ver 3.0.1699.0)
Discussion in '3CX Phone System - General' started by Max Wild, Mar 26, 2007.
  1. Max Wild
    Mar 26, 2007
    Just trying out the 3CX PBX which is fantastic and all working well... except if I try and call a digital receptionist, or access voicemail from a handset, the media server crashes within about 10 seconds.
    I noticed another similar issue from the beta, but I am using the 3.0 RC2. I have a zipped set of 'clean' logs recreating the issue if someone is prepared to take a look (Alexander seemed to be dealing with a simlar issue previously?).
    Thanks!
  2. Alexander
    Nov 10, 2006
    73
    Hi Max !
    Please send your logs to me (to my e-mail). We'll survey them thoroughly :)
    Thanks for your help :)
  3. Max Wild
    Mar 26, 2007
    Just to update on the results of sending logs to Alexander for anyone else who experiences this issue.
    It appears the PC we installed 3CX on had a corrupt DirectShow graph filter called Ligos MPEG Splitter. Initially I unregistered (regsvr32 /u lmpgspl.ax)removed the file lmpgspl.ax on Alexander's advice. This fixed the crashing, but made any MP3 prompts played by voicemail take between 3 and 9 seconds to start playing. I have now reregistered the graph filter (regsvr32 lmpgspl.ax) which has stopped the crashing, and fixed the slow to play mp3 files.
    FYI - You can download a freeware util to view all filters in use by DirectShow, and change their settings/remove them here - http://www.softella.com/dsfm/index.en.htm
    Thanks again Alexander.
