3CXPhone 6 didn't work with Hyper-V
Discussion in 'Windows' started by misstake2012, Aug 30, 2011.
  1. misstake2012
    May 23, 2011
    40
    3CX Phone System is install on server with Hyper-V - Win Server 2008 64 bit.
    If "PBX delivers audio" is disable everything work great.
    If "PBX delivers audio" is able trouble with voice is appear in 3CXPhone 6. We can't hear voice in one way.
    In Bria everything is good.
    We try to do this:
    http://www.3cx.com/forums/issue-audio-delivery-xp-sp3-amd-64-x2-4000-investigation-20204.html
    but nothing is change.
    As we think problem in 3CXPhone. It's don't work with Hyper-V.
    Can u help?
