3CXPhone and GetThreadId error
Discussion in 'Windows' started by x893, Aug 22, 2013.
  1. x893
    Aug 22, 2013
    i start 3CXPhone v.12 on Windows XP and see error message
    The procedure entry point GetThreadId could not be located in the dynamic library KERNEL32.dll
    It's new feature or bug ?
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Upgrade your operating system. No support for Windows XP
  3. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
