3CXPhone and Plantronics Savi W740 Setup
Discussion in 'Windows' started by advlaser, Aug 20, 2014.
  1. advlaser
    Oct 27, 2013
    38
    I'm attempting to setup 3CXphone for Windows with the Plantronics W740 wireless headset, but I'm running into problems.
    3CX has documented that the Plantronics Savi W740 Series is compatible. http://www.3cx.com/support/plantronics-configuration/
    According to the documentation, from the Plantronics Control Panel (ver 2.8 - the latest version), I need to select Default Softphone: 3CXPhoneForWindows. Only 3CXPhoneForWindows isn't on the list. The list includes Cisco, Avaya, Lync, Skype, etc, but no 3CX.
    I double checked the install to make sure 3CX just wasn't checked upon installation, but no joy. Has anybody had success setting up 3CX with the Plantronics Savi W740 series? Thanks!
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Are you running the Plantronics Spokes software or the Plantronics Hub ? Should be Spokes.
  3. advlaser
    Oct 27, 2013
    38
    I'm running the Spokes Software. This is strange / embarrassing, today when I double checked the settings, 3CXPhoneForWindows showed up on the bottom of the list in the Spokes software. My guess is it's a result of restarting my computer this morning. Thanks!
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Ok perfect.
