3CXPhone and tel-URI
Discussion in 'Windows' started by karli1, Jun 24, 2011.
  1. karli1
    Jun 24, 2011
    I tried to use the 3CX Phone (v.5) on a Windows PC with Internet-Explorer. I want to put a hyperlink in our Intranet-Application to allow users of 3CXPhone to dial the given number via click on it.
    the href part of the hyperlink looks like href="tel:+496991600000" this - this should work.
    can anyone help me with that?
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    an http reference like callto:+496991600000 should invoke the default phone client on the user's PC -- most probably Skype, if installed.
    Have a look at: http://eagle-bg.tel
    Regards
  3. karli1
    Jun 24, 2011
    ok, i changed the url to callto, but the 3CX Phone is not dialing, instead i get a invalid reference error in the browser.
    i don't have skype on my machine, and i don't want to install it. i want to use the 3cx Phone in this manner.
    any suggestions?
  4. eagle2
    Apr 27, 2011
    1,085
    11
    There should be a program default somewhere in Windows settings or Registry, but I can't find it.
    In 'Control Panel | Programs access and defaults' there is nothing related. However on one of my computers I have Skype installed and on another -- Counterpath Bria plus 3CX softphone on both of them. Clicking on Callto: reference invokes Skype or Bria, not the 3CX. I would appreciate if you find out how to change the Windows settings.
    See the following post: http://forum.skype.com/index.php?showtopic=192391
    regards
  5. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,516
    71
    3CXPhone never supported this feature. For version 4 and version 5 with one account, it was possible for a user to implement on its own URL protocol handler, please check this:
    http://www.3cx.com/forums/callto-feature-in-3cx-softphone-6906.html#p71446
    However, starting with ver 5 supporting multiple active accounts, implementing such kind of handler is strongly discouraged, for a simple reason: you cannot specify which account you want to use.
    Suppose you have an account to internal PBX, another one to US PBX and another a VoIP Provider, all active. You have number +00357555444333 - which of these three accounts you want to use to make this call?
  6. eagle2
    Apr 27, 2011
    1,085
    11
    Try the following:
    3cxphone.exe dial:number
    You can use the following registry entry to automate calling like dial:number
    (taken from Russian forum: http://www.3cx.com/forums/vyzov-cherez-adresnuju-stroku-20130.html)
