- Joined
- Nov 8, 2011
- Messages
- 3
- Reaction score
- 0
I've got an HTC Wildfire with 3CXPhone v1.3.4 installed, my boss has an iPhone4 with 3CXPhone v1.1.4 installed.
Our firewall is configured to allow the apps to connect:
Single ports:
5060, UDP & TCP, bi-directional
5090, TCP, bi-directional
Port range:
9000 - 9049, UDP, bi-directional
...and the apps do connect, but only up to a point.
Both the iPhone & the Wildfire show as Not Registered onscreen on their respective phones after a minute or so but, during that same time the 3CX Phone System shows them as Registered.
Some time later (about 2 minutes-ish) 3CX Phone System reports them as unregistered.
Below is an excerpt of the 3CX Phone System log entry for the Android app:
09:28:35.628|.\Extension.cpp(406)|Log2||ExtnCfg::updateContact:[CM504001]: Ext.113: new contact is registered. Contact(s): [sip:[email protected]:55216;transport=TCP;ob/113]
This is the 3CX Phone System log entry for the iPhone4 app:
09:30:47.282|.\Extension.cpp(406)|Log2||ExtnCfg::updateContact:[CM504001]: Ext.114: new contact is registered. Contact(s): [sip:[email protected]:5060;transport=TCP;ob/114]
Our VoIP provider is Spitfire (UK) - for what it's worth.
Can anyone help with this partial registration issue?
Any help gratefully received.
Mark
Single ports:
Port range:
Mark
