3CxPhone API - Available (but currently busy)
Discussion in 'CRM / Helpdesk / App Integration' started by Kyle Johansen, Mar 20, 2018.
  1. Kyle Johansen
    Mar 20, 2018
    On the client when the user is on a call there is a yellow square replacing the green one and the rollover changes from 'available' to 'available (currently..'. Is there a way to use the API to get these statuses?
    Thank you.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    893
    66
    Hello @Kyle Johansen,
    If you need the status for the current extension being used by 3CXPhone for Windows, then you can get it using the 3CXPhone API, subscribing to the events:
    - IMyPhoneCallHandler.CurrentProfileChanged
    - IMyPhoneCallHandler.ProfileExtendedStatusChanged
    If you need the information for other extensions in the system, then that's only available through the 3CX Call Control API.
    Kind regards.
  3. Kyle Johansen
    Mar 20, 2018
    Thank you,
    However although I do only the current extension those don't seem to work for me. Whenever I check the profile for status, I only get 'available' and not the '(Is busy now)' text.
  4. edossantos
    Jun 27, 2007
    893
    66
    That's because the profile is not really changing. Just the extension is in a call... You need to check if you have an active call or not, you have the event "IMyPhoneCallHandler.OnCallStatusChanged" that will notify you about any change regarding calls on the current extension.
  5. Kyle Johansen
    Mar 20, 2018
    That doesn't work when the user uses their softphone to pick up the call (which is what we expect them to do). I think I have to use the Call Control, thanks for your help.
  6. edossantos
    Jun 27, 2007
    893
    66
    The 3CXPhone API should give you those notifications if you're using a PRO license key... If you're not receiving them, maybe you have a STD license?
