3CXPhone Auto Provision to DMZ
Discussion in '3CX Phone System - General' started by geoff.jukes, May 3, 2013.
  1. geoff.jukes
    Apr 10, 2013
    14
    I want to place our 3CX PBX into our DMZ. I have set up auto-provisioning for our Polycom handsets, using 'Option 66' in DHCP, and this works perfectly.
    However, I would like to be able to 'Auto Provision' the 3CXPhone users, running on Windows PCs on the LAN.
    I have full control of the Firewall configuration, and can set up anything required.
    My main question is; how does the 3CXPhone 'Auto Provision' method work? Specifically, how does it 'find' the 3CX PBX?
    I know I can manually provision the soft phones etc, but I really liked the functionality that 'Auto Provision' (the pop-up when you first run the 3CX SoftPhone) gave me. I could just tell people to install the software, and I can create extensions as needed.
    Can anyone help?
    Many thanks,
    Geoff
    10,375
    231
    A lot will depend on what type of set(s) you plan on deploying.
    http://www.3cx.com/sip-phones/dhcp-option-66/
    http://www.3cx.com/sip-phones/3cx-voip-phone/
    http://www.3cx.com/sip-phones/cisco-spa/
    There are more examples if you search the forum.
