3CXphone Citrix Support
Discussion in 'Ideas' started by cs1, Dec 12, 2016.
3CXphone Citrix Support 5 5 9votes
5/5, 9 votes
  1. cs1
    cs1
    Apr 13, 2009
    We need Citrix Support.
  2. macfusion
    Aug 4, 2015
    5
    This would be useful for me. A 3CX customer plans to move to a new office late 2017 and grow the business from 40 to 200 over 2 years. The new IT infra-structure is planned to be Citrix and ideally all users in the call centre (approx 180) would have access to 3CXPhone as a desktop service.
  3. ckatterl
    Nov 15, 2016
    55
    6
    Me too, support for Citrix environments would make my life easier :)
  4. geracilaw
    Nov 30, 2016
    6
    This would be great feature for 3CX, If you Suppport XenApp 7.5 or
  5. Steven Aleman
    Dec 22, 2016
    This would be useful for me it is a great feature to have.
  6. EasyComp Zeeland
    Nov 6, 2016
    14
    Actually if install 3cx client to a win pc then copy the installation folder to a Citrix location. it might work... however im not 100% sure about this, it seemed logic..
  7. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Please do support Citrix environment. Should not ignore how widely spread citrix is...
  8. 3CXAchermann
    Aug 18, 2015
    This would also be very useful for us!
  9. Tifoso
    Oct 17, 2017
    58
    9
    3CX Softclient should work in Citrix. Skype for buisneess or Cisco Jabber has a solution!
    More and more customer are using the virtualization and the softclient should work in this environment. IP phones and 3CX CTI mode is often no case. customers won't IP phones.......
    Please implement it in next releases.
  10. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Well, did You know that 3CX is working on Citrix? The only real bug is that playing chat notification sounds will crash the 3CX client. Disable them
  11. Tifoso
    Oct 17, 2017
    58
    9
    official 3cx in softmode is not supported.
    do you have other news? Does it need special settings in citrix?
  12. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Yeah, it is not supprted, but it works if your bandwith is good enough. otherwise there is much noise.
    When I use it in LAN environment it works very well.
  13. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    This is my powershell script to disable chat sound notifications, enable chat popup notification and replace + by 00
    if((get-process "3CXWin8Phone" -ea SilentlyContinue) -eq $Null){
    echo "3CX not Running"
    else{
    echo "3CX Running"
    echo "Trying to kill..."
    Stop-Process -processname "3CXWin8Phone" -ErrorAction SilentlyContinue -Force
    $path="$Env:USERPROFILE\AppData\Roaming\3CXPhone for Windows\3CXPhone.xml"
    $xml=[xml](Get-Content $path)
    $xml.Data.Course.Subject
    $node=$xml.Accounts.Profiles.Profile
    $node.ChatSoundFile='None'
    $node.AutomaticallyOpenChatWindow='True'
    $node.UseInternationalDialingCode='True'
    $node.InternationalDialingCode='00'
    $xml.Save($path)
    please do support this feature request:
    https://www.3cx.com/community/threads/choose-to-receive-internal-but-not-external-calls.49529/
  14. Tifoso
    Oct 17, 2017
    58
    9
    okey thanks a lot.
    But I would like to have official support of this function.
  15. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    sure, it is absolutely necessary. 3CX loses lots of possible customers because of that.
    Michael1983 likes this.
