3CXPhone crashes on start
Discussion in 'Windows' started by KGarrison, Jan 27, 2014.
  1. KGarrison
    Jan 27, 2014
    Windows 7 Professional (two different systems)
    Reinstalled current version of 3CX
    .Net Framework 4.5 installed
    3CX Phone starts but crashes when screen says Loading Presence Information
    This happens on both systems
  2. KGarrison
    Jan 27, 2014
    For fun I updated one machine to .net 4.5.1 and now 3CXPhone says there is an update available from your 3CX phone system and then quits.
  3. norekhov
    3CX Support
    Jan 31, 2014
    53
    3CXPhone is developed and tested with .NET 4.0. Please, install this version of framework.
    Regards, Nikolai Orekhov
    Software developer @ 3CX
  4. KGarrison
    Jan 27, 2014
    Application: 3CXWin8Phone.exe
    Framework Version: v4.0.30319
    Description: The process was terminated due to an unhandled exception.
    Exception Info: System.Reflection.TargetInvocationException
    Stack:
    at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
    at System.Windows.Threading.DispatcherOperation.InvokeImpl()
    at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(System.Object)
    at System.Threading.ExecutionContext.runTryCode(System.Object)
    at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode, CleanupCode, System.Object)
    at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
    at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
    at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
    at System.Windows.Threading.DispatcherOperation.Invoke()
    at System.Windows.Threading.Dispatcher.ProcessQueue()
    at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
    at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
    at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
    at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
    at System.Windows.Threading.Dispatcher.InvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
    at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
    at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
    at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
    at System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame)
    at System.Windows.Threading.Dispatcher.Run()
    at System.Windows.Application.RunDispatcher(System.Object)
    at System.Windows.Application.RunInternal(System.Windows.Window)
    at System.Windows.Application.Run(System.Windows.Window)
    at _3CXWin8Phone.App.Main()
  5. KGarrison
    Jan 27, 2014
    Faulting application name: 3CXWin8Phone.exe, version: 12.0.33517.0, time stamp: 0x5294d23a
    Faulting module name: KERNELBASE.dll, version: 6.1.7601.18229, time stamp: 0x51fb1116
    Exception code: 0xe0434352
    Fault offset: 0x0000c41f
    Faulting process id: 0xb6c
    Faulting application start time: 0x01cf2107166cc302
    Faulting application path: C:\ProgramData\3CXPhone for Windows\PhoneApp\3CXWin8Phone.exe
    Faulting module path: C:\Windows\syswow64\KERNELBASE.dll
    Report Id: 583054af-8cfa-11e3-b8d9-f04da2dd544d
  6. norekhov
    3CX Support
    Jan 31, 2014
    53
    Please, could you give me the whole information from Event Viewer? This could help a lot.
    Also If you have a log file, please, send it to me.
    Usually it will be at c:\Documents and Settings\user\AppData\Roaming\3CXPhone for Windows\Logs
  7. norekhov
    3CX Support
    Jan 31, 2014
    53
    Also, please could you send me your 3CXPhone.xml so I can run it on mine and try to reproduce?
  8. rmelching
    Aug 10, 2009
    same problem here with windows 8.1. How did you fix the problem??????
  9. leejor
    11,123
    330
    You are running a different operating system and don't even mention which version of 3CX you are dealing with. You should have started a new topic and included additional information.
