3cxphone distinctive ringtone internal/external ?
Discussion in 'Windows' started by alex6, May 27, 2012.
  1. alex6
    Apr 11, 2012
    14
    Hello i am french and i am testing 3cx v11
    How can i set Distinctive ringing for the 3cx phone, there is no template for 3cx phone ?
    I am using snom M9 dect phone and they doesn't support the alert info so i try to find an issue to have Distinctive ringing for internal and external call.
    The only issue i find it is to instal 3cx phone on every computer and every extension will use 3cx phone and a snom M9.
    Thank's
  2. alex6
    Apr 11, 2012
    14
    Nobody ?
  3. clflyer
    Jun 5, 2012
    I think I found a solution to your problem. There is a wav file you can change ringing.wav.
    I am running Windows 7 and found the file here: C:\Program Files (x86)\3CXPhone\Sounds\ringing.wav
    I made a copy of the original and substituted a different one.
    :D
  4. leejor
    11,116
    329
    Changing that file may change the (one) ringtone, but the query is regarding different ringtones to indicate an internal and and external call. I'm not sure that this is yet supported.
  5. alex6
    Apr 11, 2012
    14
    It should be supported because it is very basic
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
  7. abners
    Jul 9, 2012
    Image no longer available
  8. alex6
    Apr 11, 2012
    14
    Nothing new about this ?
  9. craigreilly
    Feb 1, 2012
    3,575
    305
    Alex
    There is only 1 ring. You should submit this in the ideas app on facebook
  10. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    There is another post similar to this though the answer was no there as well you can change the ringtones though not a different tone for internal and external calls.
