3CXPhone - Error occurred in application current domain
Discussion in '3CX Phone System - General' started by Marin, Jun 2, 2017.
  1. Marin
    Mar 16, 2017
    11
    Hello...
    We are preparing new Virtual Machines for our users (User Computers) with:
    - Windows 10 Pro 64bit / 3CXPhone Version 14.0.49169.0
    After longer period of inactivity on VM (cca. more than 3h), when user logs in to Virtual machine, in that exact moment 3CXPhone is crashing with following in LOG file (complete LOG file attached)... I have tried everything, but without success. I am sure that this error comes in the exact moment when user logs in to the VM.
    [02.06.2017 08:51:08.543][1] Error occurred in application current domain - app domain unhandled exception
    [02.06.2017 08:51:08.566][1] System.OutOfMemoryException: Nicht genügend Speicher verfügbar, um das Programm weiter auszuführen.
    bei System.Windows.Media.Composition.DUCE.Channel.SyncFlush()
    bei System.Windows.Interop.HwndTarget.UpdateWindowSettings(Boolean enableRenderTarget, Nullable`1 channelSet)
    bei System.Windows.Interop.HwndTarget.UpdateWindowPos(IntPtr lParam)
    bei System.Windows.Interop.HwndTarget.HandleMessage(WindowMessage msg, IntPtr wparam, IntPtr lparam)
    bei System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
    bei MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
    bei MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
    bei System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
    bei System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
    bei System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
    bei MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @Marin,
    I have sent you a p.m. Please check your inbox.
