3CXPhone for Android DISCONNECTED
Discussion in 'Android' started by 9009, Jul 1, 2016.
    Jun 19, 2016
    32
    I am using 3CX v14 on a Windows 10 PC and have installed 3CXPhone for Android on a Nexus phone. The 3CXPhone is registered with PBX and can receive calls when a caller calls the PBX and enters the assigned extension, but the 3CXPhone shows DISCONNECTED and I can NOT make calls from it.
    I have configured Android PUSH and it works.
    I have all the required ports forwarded, as shown here: http://www.3cx.com/blog/docs/ports-used/
    What can I do to fix this?
    Thank you.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,340
    533
