3cxphone for android - Registration failed
Discussion in 'Android' started by sgleser, Jun 27, 2012.
  1. sgleser
    Apr 21, 2008
    3cxphone 2.0.5
    Samsung Galaxy Tablet.
    Wifi connection. No 3G
    I can not connect using the tunnel over Internet.
    The credentials, ports, ips are correct
    The PC with the software (3cx phone) for windows works ok.
    Same router, connection, server, etc..
    On tablet ...
    Reading configuration
    Tunnel connecting
    Not registered.
    Registering ...
    Not Registered
    Any ideas ?
    Sergio.
  2. mixig
    mixig Active Member
    Dec 13, 2011
    522
    12
    For that extension did you check settings for "disallow use extension outside the LAN" ?
    Do you have some messages in server activity/event log?
    Does your tunnel is connected before you got message not registered / register failed?
  3. cwooster
    Apr 13, 2012
    sgleser,
    Did you even figure out what the problem was? I have the same issue.
    I am seeing traffic passing through the firewall and wireshark is showing the traffic reaching the 3CX phone server. I do not see anything in the 3CX logs
    Craig
