3CXPhone for Mac
Discussion in 'Windows' started by complex1, Sep 15, 2014.
  1. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    I know that the 3CXPhone for Mac does not support the CTI mode, but do the 3CXPhone for Mac support the “MakeCall” mode?
    I have install the 3CXPhone for Mac on a Mac and when I start a call using “MakeCall” the deskphone (Yealink W52P) won’t be called from the 3CX Phone System.
    The call will only be made directly from the Mac.
    When using 3CXPhone for Windows and the same deskphone, then there are no issues, it is possible to make calls.
    3CXPhone for Mac/Windows use the same credentials as the deskphone.
    3CX v12 SP6
    3CXPhone for Mac v1.0.42
    Thank you.
  2. carlsson
    Feb 2, 2015
    I also have this question and problem. Have mailed the 3CX support to no avail.
    Did you find any solution?
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,441
    61
    No, it's not supported - we will announce when it will be available.
  4. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    Anyone have a OSX CTI/Yealink software recommendation?
  5. carlsson
    Feb 2, 2015
    Thanks for the info Vali!
