3CXPhone For Windows 15 Will Not Start on Windows 7
Discussion in 'Windows' started by Mwamba, Mar 28, 2018.
  1. Mwamba
    Sep 20, 2017
    35
    I am installing 3CX on a 64 bit windows 7 computer. The client installs okay but it does not launch. Both Visual C++ 2010 and 2015 have been successfully installed. I have checked the 3CX Phone log and I can see the following error:
    System.IO.FileNotFoundException: Could not load file or assembly 'VCEWindows8Agent.dll' or one of its dependencies
    I have tried uninstalling 3CX, rebooting the laptop and installing 3CX again but the issue still persists. Does anyone have a solution for this issue?
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    13
    Hello @Mwamba,
    Try and uninstall the application again and this time remove PhoneApp folder from C:\ProgramData\3CXPhone for Windows and install again.
  3. Mwamba
    Sep 20, 2017
    35
    I did as you said. I uninstalled the client, restarted the computer and then installed it again. The error is still the same.
    Code:
    [29.03.2018 08:41:28.238][1] Starting application
    [29.03.2018 08:41:28.240][1] Initializing configuration
    [29.03.2018 08:41:28.279][1] Loading configuration file C:\Users\admin\AppData\Roaming\3CXPhone for Windows\3CXPhone.xml
    [29.03.2018 08:41:28.279][1] Configuration file C:\Users\admin\AppData\Roaming\3CXPhone for Windows\3CXPhone.xml does'not exist
    [29.03.2018 08:41:28.279][1] Trying to load backup configuration
    [29.03.2018 08:41:28.279][1] Loading configuration file C:\Users\admin\AppData\Roaming\3CXPhone for Windows\3CXPhone.xml.back
    [29.03.2018 08:41:28.279][1] Configuration file C:\Users\admin\AppData\Roaming\3CXPhone for Windows\3CXPhone.xml.back does'not exist
    [29.03.2018 08:41:28.279][1] Using empty configuration
    [29.03.2018 08:41:28.285][1] Initializing configuration with existing xml configuration
    [29.03.2018 08:41:28.316][1] Initializing supported languages dictionary
    [29.03.2018 08:41:28.361][1] Merging string resource dictionary
    [29.03.2018 08:41:28.445][4] Opening named pipe for IPC
    [29.03.2018 08:41:28.530][1] Pro only added CallTriggerCmdPlugin, Version=15.5.0.0, Culture=neutral, PublicKeyToken=null
    [29.03.2018 08:41:28.531][1] Pro only added CallTriggerCmdPlugin, Version=15.5.0.0, Culture=neutral, PublicKeyToken=null
    [29.03.2018 08:41:28.532][1] Pro only added CallTriggerCmdPlugin, Version=15.5.0.0, Culture=neutral, PublicKeyToken=null
    [29.03.2018 08:41:28.533][1] Pro only added CallTriggerCmdPlugin, Version=15.5.0.0, Culture=neutral, PublicKeyToken=null
    [29.03.2018 08:41:28.554][1] Pro only added DotNetScriptPlugin, Version=15.5.0.0, Culture=neutral, PublicKeyToken=bac47dd19dc4098a
    [29.03.2018 08:41:28.557][1] Initializing main window
    [29.03.2018 08:41:28.578][1] Error occurred during application startup
    [29.03.2018 08:41:28.590][1] System.Windows.Markup.XamlParseException: Provide value on 'System.Windows.Markup.StaticExtension' threw an exception. ---> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.TypeInitializationException: The type initializer for '_3CXWin8Phone.ViewModel.DialPadOperationsVM' threw an exception. ---> System.TypeInitializationException: The type initializer for '_3CXWin8Phone.Biz' threw an exception. ---> System.IO.FileNotFoundException: Could not load file or assembly 'VCEWindows8Agent.dll' or one of its dependencies. The specified module could not be found.
       at _3CXWin8Phone.Biz..ctor(IResourceLoader resourceLoader)
       at _3CXWin8Phone.Biz..cctor()
       --- End of inner exception stack trace ---
       at _3CXWin8Phone.Biz.get_Instance()
       at _3CXWin8Phone.ViewModel.DialPadOperationsVM.InitializeMyPhoneVM()
       at _3CXWin8Phone.ViewModel.DialPadOperationsVM..ctor(IResourceLoader resourceLoader)
       at _3CXWin8Phone.ViewModel.DialPadOperationsVM..cctor()
       at System.RuntimeFieldHandle.GetValue(RtFieldInfo field, Object instance, RuntimeType fieldType, RuntimeType declaringType, Boolean& domainInitialized)
       at System.Reflection.RtFieldInfo.UnsafeGetValue(Object obj)
       at System.Reflection.RtFieldInfo.InternalGetValue(Object obj, StackCrawlMark& stackMark)
       at System.Reflection.RtFieldInfo.GetValue(Object obj)
       at System.Windows.Markup.StaticExtension.GetFieldOrPropertyValue(Type type, String name, Object& value)
       at System.Windows.Markup.StaticExtension.ProvideValue(IServiceProvider serviceProvider)
       at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CallProvideValue(MarkupExtension me, IServiceProvider serviceProvider)
       at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
       at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
       at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
       at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
       at _3CXWin8Phone.MainWindow.InitializeComponent()
       at _3CXWin8Phone.MainWindow..ctor()
       at _3CXWin8Phone.App.Application_Startup(Object sender, StartupEventArgs e)
    I checked the C:\ProgramData\3CXPhone for Windows\PhoneApp folder and the file VCEWindows8Agent.dll is there.
  4. Marios Neophytou
    Mar 1, 2016
    258
    13
    Check if the windows 7 machine has the latest updates and Service Pack 1
    Check if vs2015 C++ X86 Redistributable is installed on the machine
  5. Mwamba
    Sep 20, 2017
    35
    I will check on the windows updates and see whether that is the issue. The machine is running SP1.
  6. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    Let us know if this solves your issue.
  7. Mwamba
    Sep 20, 2017
    35
    I will, the client is on Easter Break. So I will bring a response on Tuesday.
  8. LeonidasG
    Nov 19, 2008
    1,557
    118
    Managed to reproduce this error just by uninstalling Visual Studio 2015 / 2010 dependencies.
    Looks like your client uninstalled this but also expects the 3CX Client to work. There's your problem.
    #8 LeonidasG, Apr 2, 2018
  9. Mwamba
    Sep 20, 2017
    35
    Hi @LeonidasG
    Sorry for the delayed response. I checked the computer and it has Visual C++ 2010 and 2015 installed. I added the 64 bit versions of the same and it is still not working.
    The PC is running Windows 7 SP1 as shown:
    Both Visual C++ 2010 and 2015 are installed:
  10. Marios Neophytou
    Mar 1, 2016
    258
    13
    Hello @Mwamba ,
    Does VCEWindows8Agent.dll exist on the PhoneApp folder under ProgramData after you uninstalled/installed the app?
  11. Mwamba
    Sep 20, 2017
    35
    Yes the VCEWindows8Agent.dll file is always there even after I deleted the folder and did the reinstallation
